anyone using spacers or rims with lower ET
Old Mar 8, 2021 | 07:35 AM
boni's Avatar
Default anyone using spacers or rims with lower ET
Hi there,
Is anyone using wheel spacers on the standard 20" rims or using non-standard rims with a lower ET value? The standard 20" rims have an ET value of 41.5 mm and I plan to use non-standard rims with ET value 26.5 mm. That would boil down to using wheel spacers of 15mm on standard rims.
So my wheels with these new non-standard rims will stick out 15mm wider on each side. Wonder if anyone has done this and can take a picture of how far those wheels stick out of the Defender's body chassis in real life.
Thanks.
Have a Defender 90 X-Dynamic HSE on order, delivery planned for May 2021.
Old Mar 8, 2021 | 03:39 PM
Ehloo's Avatar
another member used 30mm spacers pushing the net offset to around 10 et. the wheels sit completely flush with this offsets
spacers that large are expensive and i ended up getting new wheels with an offset of 10mm. stance is perfect and flush
but if you are planning to run larger AT tires you might rub. i have 275/55/20 BFG K02 with a PR inch lift. i rub in reverse at access height full lock only in reverse.
got in the habit of lifting the car before j take it out of the garage. this is in off-road
[QUOTEanoth=boni;764475]Hi there,
Thanks.
Have a Defender 90 X-Dynamic HSE on order, delivery planned for May 2021.[/QUOTE]
Old Mar 9, 2021 | 01:02 AM
boni's Avatar
nice set-up; car looks great. Great to have such big garage :-), can't lift my car before driving out my garage :-(
Anyway, your picture makes me feel comfortable with my choices. Thanks you for your reply, and the picture.
landroverdude
Jun 12, 2020 04:58 PM
RhinoRover
May 2, 2017 06:45 AM
lordiasd
Jan 29, 2016 01:45 PM
carid
Appearance & Camping Set Ups
Dec 12, 2014 07:56 AM
XDdisco
Dec 14, 2012 10:57 AM
