Audio issue
Audio issue
My audio in the 2020 Defender will go silent after I use Siri to make a phone call with my iphone. The iphone is connected via bluetooth, and works fine and will play music prior the making a call using Siri. Right after the phone call ends, the audio goes out and I cannot play any music from my iphone. Even switching to radio (AM, FM or Sirius) will not change the silent audio. When this happens, the unit will not reset itself when you hold the power button down for the 15-20 seconds. When you restart the car, everything will work again.
Has anyone experienced this issue? Any input or suggestions would be welcomed. Thank you.
GFranklin (06-11-2021)
Thanks for the suggestion. I'll try that. It seems like the audio controls go away, so that would make sense. I'll let you know when I get it back from the dealership and it happens again.
Not sure if there is a real fix but the above suggestion of holding the power button till the system restarts did the trick for me. I assumed there was a way to restart but couldnt find it in the menu and the first time I tried holding the button to restart I guess I just didnt hold it long enough. Good luck.
