Audio issue
Old Dec 19, 2020 | 05:26 AM
wcc18999's Avatar
Default Audio issue
My audio in the 2020 Defender will go silent after I use Siri to make a phone call with my iphone. The iphone is connected via bluetooth, and works fine and will play music prior the making a call using Siri. Right after the phone call ends, the audio goes out and I cannot play any music from my iphone. Even switching to radio (AM, FM or Sirius) will not change the silent audio. When this happens, the unit will not reset itself when you hold the power button down for the 15-20 seconds. When you restart the car, everything will work again.
Has anyone experienced this issue? Any input or suggestions would be welcomed. Thank you.
Old Mar 1, 2021 | 10:09 PM
RunNguN29's Avatar
7th Gear
I'm having the same issue with mine. Sometimes mine won’t come on for days at a time. Did you ever find a fix for this? Tired of taking this thing for every little thing and losing the vehicle for 3 days.
Old May 27, 2021 | 10:43 AM
Mateo1234's Avatar
Same thing is happening to me. Exactly.
– Mateo
Old May 27, 2021 | 03:55 PM
BulldogDefender's Avatar
Similar issue. Frustrating for sure.
Old May 27, 2021 | 04:56 PM
umbertob's Avatar
If you turn off or reset your iPhone, does the audio come back? I am wondering if the iPhone "hijacks" the audio inputs (the car system thinks Siri is still active and won't let it go.)
Old May 28, 2021 | 01:34 PM
Mateo1234's Avatar
Thanks for the suggestion. I'll try that. It seems like the audio controls go away, so that would make sense. I'll let you know when I get it back from the dealership and it happens again.
Old Jun 11, 2021 | 08:16 PM
GFranklin's Avatar
Default Sound going out
Same here, especially if using Spotify. If a call or even the navigation system comes on it causes everything to quit, and restarting the car is the only fix, sometimes!! And it’s pretty frustrating when you are on the highway!!
Old Jun 11, 2021 | 11:29 PM
TripleF's Avatar
Hello,
I had the exact same issue with my 2020 Defender. Mine stopped correcting itself after I shut down the vehicle.
I took it into Land Rover and they did a software update (maintenance only, not the self update). It fixed it right away and hasn't come back in 4 months. Good luck!
Old Jul 17, 2021 | 01:46 AM
SaltyHaggis's Avatar
Default Update?
Hi, just got our new Defender, and seem to be having this same issue - has anyone found a fix for it yet? Thanks!
Old Jul 18, 2021 | 01:58 PM
jwasson68's Avatar
Not sure if there is a real fix but the above suggestion of holding the power button till the system restarts did the trick for me. I assumed there was a way to restart but couldnt find it in the menu and the first time I tried holding the button to restart I guess I just didnt hold it long enough. Good luck.
