Bad Design: Wipers
Old Feb 4, 2022 | 09:57 AM
  #21
warkeld's Avatar
Originally Posted by swajames
I wonder how many of those having problems don’t have the cold climate pack which has heated washer jets and of course the heated windshield
I have cold climate pack, should it have heated washer jets? I do have heated windshield and it works great but again, my fluid jets were completely frozen up until the temp went above freezing, then they started working again.
Old Feb 4, 2022 | 10:13 AM
  #22
Chief65's Avatar
I've never seen a control for heating the jets, I'm assuming it heats them similar to the way the side mirrors heat. Not sure it's always working properly, sometimes even when it's below freezing for example if you have the windshield set to heat automatically you start the engine and the windshield heat does not come on, though the rear will sometimes and not others, very strange the way it works. Happened to me this morning in 15 degree F weather. So I think there's bugs in the way that sensor is working. I'm not a huge fan of the way the windshield heater works either. Basically you turn it on, it heats for a couple of minutes and turns off and I can understand why it needs to stop for a while. It doesn't cycle back on though say a couple of minutes later, so you have to keep pressing it every few minutes to keep it heated, there are conditions where I am right now where I'm pressing it literally dozens of times per day and I don't even drive for a living, these are just grocery runs and lunch. I don't have a problem with it cycling these various heated bits but that's not what we have at the moment. The steering wheel stays heated regardless though, no complaints with that.
clarkritchie
Feb 1, 2017 02:29 PM
Kurgan7777
Freelander
Dec 21, 2015 05:32 AM
logic2
Dec 9, 2013 12:23 PM
btgregory
Feb 1, 2010 12:03 AM
99LRDisc
Sep 30, 2008 04:45 PM
