Battery Tap
Old Feb 22, 2021 | 02:56 PM
Landy718's Avatar
Default Battery Tap
Anyone pull accessory power? I'd like to pull it directly from the battery to a new fuse panel.
Old Feb 22, 2021 | 05:50 PM
Landy718's Avatar
And where is the battery located!? Manual basically says no touchie and nothing more.
Old Feb 22, 2021 | 05:51 PM
ADVAW8S's Avatar
Under the passenger seat in US and Driver seat EU. SLide the seat forward and pull the black cover
Old Feb 22, 2021 | 07:32 PM
Landy718's Avatar
Thanks! Will investigate. Going to add a Switch Pros switching kit, breaker at the battery, aux fuse panel and some work lights to the rack I'm working on. Will report back with results.
Old Feb 23, 2021 | 03:42 PM
zac431's Avatar
I ran a cable from the battery positive to the rear cargo area for a dual battery setup. Works fine, but it was a pain to run the cable under the rear rubber floor. There is a lot of space under the floor of the rear cargo area (especially on the p300), could easily put an aux fuse panel back there.
escott16
May 13, 2020 11:07 PM
Yasser Iskandar
Sep 23, 2018 07:58 PM
olywa
Nov 10, 2015 06:02 PM
yarddawg
Jan 15, 2008 07:40 PM
Tink
Audio/Visual Electronics
May 1, 2007 12:37 PM
