Best Jack w/ Lucky 8 Rock Sliders
Keeping the door ajar will disable the ability of the Defender to lower the vehicle when it decides it wants to, say from off-road height to regular height (or access mode). I have not been able to find how to have any action in the other direction (keeping the suspension from trying to lift the vehicle). .
Keeping the doors open (a couple of them in case someone comes by and tries to close one before you can yell not to) -- along with using jack stands -- is a very important safety feature when you have raised the vehicle to place yourself under it, or between the body and wheel / suspension, in order to place or remove your lift rods when off-roading, if you use lift roads temporarily.
Enjoy ! (and be safe).
Apologies for reviving an old thread, but what is the consensus here for the best jack for both on/off road for a rig that has the Lucky8 sliders? I remain confused as to if I she get the ARB or a the bottle jack kit (both and carry the ARB when off roading and the bottle jack when on the highway)?
Appreciate some insight and guidance, thanks.
Apologies for reviving an old thread, but was is the consensus here for the best jack for both on/off road for a rig that has the Lucky8 sliders? I remain confused as to if I she get the ARB or a the bottle jack kit (both and carry the ARB when off roading and the bottle jack when on the highway)?
i figure the ARB is more than good enough for emergencies on or off road, the floor jack is for things like rotations
Craig_RRS2013 (03-26-2023)
I once saw a jack (bear with me as I try to cobble together a description) where the jack looked like a high lift with a pin instead of the lift arm. The pin just slotted into a rock slider hole and easy peasy. Anyone seen something like that? Wonder if that would work with a set of proper sliders. I think it was for a rally vehicle so it may have been just a custom lift tool. I'm not sure it was materially better than a hi-lift though. Would have the same space challenges.
GrouseK9 (03-28-2023)
