On board air compressor FUSE?
Old Jun 15, 2021 | 07:46 PM
sayvillerx's Avatar
Default On board air compressor FUSE?
i finally tried out my on board air pump to blow up a pool float and within 30 seconds i got an E4 error and it wouldn’t work.
Today I try again and the thing doesn’t even turn on. the cigarette lighter underneath doesn’t work either…..so i guess it’s a fuse.
i can’t find any info online, not even the manual! Does anyone know where the fuse is located?
thanks!
Old Jun 15, 2021 | 07:51 PM
Akrna's Avatar
thanks!
I had the same issue. Dealer put it in a couple weeks ago and when I went to test it on the spare it worked for a few seconds then blew a fuse. Changed fuse twice and blew both times. I believe it is fuse number 20 in the back directly opposite the compressor. Someone responded the the PowerfulUK video that they had the same issue and it was a bad compressor. They are due to replace mine tomorrow, so hoping that is the fix.
Old Jun 15, 2021 | 07:58 PM
sayvillerx's Avatar
thank you. i’ll swap the fuse and prepare for the worst. 🤬
im kinda annoyed
Old Jun 15, 2021 | 07:59 PM
Akrna's Avatar
im kinda annoyed
I hear ya! Good luck and report back!
Old Jun 15, 2021 | 08:21 PM
sayvillerx's Avatar
while we’re on it, does the engine need to be running to use the compressor??
is it helpful if it is? i’m thinking it shouldn’t matter
Old Jun 15, 2021 | 08:22 PM
Akrna's Avatar
Yes, it does!
Old Jun 16, 2021 | 07:31 PM
sayvillerx's Avatar
any chance it’s not spot “20”…..mines empty! uggh
Old Jun 16, 2021 | 07:52 PM
Akrna's Avatar
check 19? The powerfulUK video on YouTube has more info.
Old Jun 16, 2021 | 08:40 PM
sayvillerx's Avatar
i pulled out the fuse, it was fine, then i put it back and the dumb thing works again.
i need to find the manual for this thing…
im starting to think this wasn’t the best way to spend 1000.
Old Jun 16, 2021 | 08:43 PM
Akrna's Avatar
directions are at the bottom of this: LAND ROVER ACCESSORY FITTING INSTRUCTIONS
Akrna
Jan 9, 2022 02:48 PM
blaster1232
Jul 13, 2015 04:37 PM
Pet
Aug 2, 2014 09:55 PM
cold_surfer
Feb 6, 2008 06:30 PM
thisisheaven
Jul 12, 2007 01:03 AM
