C pillar badge part number/source?
Old Apr 26, 2025 | 03:29 AM
fatphoca's Avatar
Originally Posted by Darover2
Got mine on ebay as a set of 2, one for the side and one for the back.
Best part is that I was able to center it perfectly in the ladder area, where it normally sits offset inside the ladder which looks off.
May I ask if you centre it on the ladder, is it also centred on the rear panel?
I was thinking of removing my oval embedded badge when my 110 gets wrapped and replacing it with a larger rectangular Union Jack badge which i hope is big enough to allow it to be centred on the rear panel but without a ladder for reference was not sure if this would end up being centred on the ladder, if I ever get one? Thanks.
Old Apr 28, 2025 | 10:55 AM
CincyRovers's Avatar
If you have a Land Rover badge on your C-pillar, it has an indentation on the square for the badge. If you put a Union Jack in the center, you will have an indentation where the Green Oval would go, and it would be incredibly visible. Unless I'm reading this wrong and want to try to center the Union Jack over the oval indentation.
Old Apr 28, 2025 | 03:21 PM
Darover2's Avatar
I couldn’t tell you as I havent taken the ladder off. For me, since I do have a ladder, the importance was for the badge to be centered in the ladder area. 🤷‍♂️
Old May 9, 2025 | 01:00 AM
honolulugator's Avatar
Here’s a f/u answer to the question for the badge only (not the whole square thingy)…
LR060140
The easiest way to get two if you want to add the badge on your 2025 is as stated above, Lucky 8 don’t be a square delete kit
mtaylo32
Nov 19, 2023 07:18 PM
FLwolverine
Aug 29, 2022 12:33 PM
Rufflyer
May 14, 2021 06:04 AM
Hildebrandt
Feb 19, 2020 08:55 PM
cornbreadj
Jun 1, 2015 08:26 PM
