Cabin water leaks
Cabin water leaks
Hi. I have a new 24 X Dynamic delivered early March 2024. Less than 1k miles on it.
This is a US spec LHD model.
I just noticed some puddles on the driver side footwell and the “cubby” just to the left of the gauge cluster. The weather has been rainy so no doubt this is penetrating somehow.
Attaching a few photos. The red mark ups are where I had water appearing to drip from before pooling in the footwell.
There was water both on top of and beneath the rubber mat.
There was some that dumped out when I opened the door. It was a good bit really - far more than you want inside your car!
I’m not finding any trim that feels damp or discolored - headliner, a piller, dash, etc.
is this a known thing or am I just lucky?? I vaguely recall reading about A Pillar leaks but the search isn’t turning anything up for me. Too many coolant leak threads 😆
I’ve troubleshooted a bit without a hose and I’m suspecting inner door seal. It’s pretty wet behind the fold. Not seeing the same thing on the passenger side.
detecting some moisture half way up near where the dash meets and I’m guessing it might be running downhill and splitting off behind the dash and down to the floor
Can_Glu (04-08-2024)
Please keep us posted on what they find out. I had the same issue with similar leaks on both driver and passenger footwells. When I took it in the first time, they said it was coming from the windshield but that did not resolve the issue. The footwells got wet again after the windshield got replaced and they could not find anything after checking all the drains and the seals of the pano roof. I will have them check the door seals. Thanks for sharing your pictures.
johhn14 (04-09-2024)
