Cannot back up with the driver's door open?
Old Jul 10, 2021 | 03:48 PM
umbertob's Avatar
Trio, I had a few minutes to spare while waiting for my daughter's music class to finish and I think I figured it out. To maneuver in reverse (or forward, seems to work the same) with the driver's door open, first disable Rear Traffic Braking. Don't ask me why, but it works for me. When you select Reverse, open the door and press on the gas pedal, it might ask you to re-select the Reverse gear (after warning you the door is open) to make sure you really mean it, but it will then allow you to back up. If you come to a stop and then resume backing up, you won't have to deal with the automatically set park brake anymore. Same if you select Drive instead of Reverse. Try it out to confirm, please? Rear Traffic Braking is under Settings > Vehicle > Driver Assistance > Collision Avoidance.
Old Jul 10, 2021 | 04:08 PM
TrioLRowner's Avatar
Nice !! Thank you, umbertob.
I will try it as soon as I get a chance to next drive it.
Old Jul 10, 2021 | 08:28 PM
GrouseK9's Avatar
Thanks, @umbertob !! Definitely going to try it out.
Old Jul 12, 2021 | 10:36 AM
MrBreeze's Avatar
Thanks umbertob!!
Old Jul 16, 2021 | 10:33 AM
Default My 2020 110 S P300 does not have the software.
I tried to find the rear traffic braking toggle but none exists.
in fact, the settings menu is much different entirely. I suspect this is a result of me not buying any of the optional electronic gadgets.
and maybe the year 2020 has a different setup?
Old Jul 16, 2021 | 10:57 AM
GrouseK9's Avatar
PowerfulUK/Simon has a GREAT aid to the menu tree. He created an XLS on the flow here: https://www.youtube.com/redirect?eve...Fusp%3Dsharing
And a video, here:
The doc is in the comments if that first link doesn't work. Hopefully it helps to locate it on the menu for you.
Old Jul 16, 2021 | 11:51 AM
Default Simon has a 2020 110 S P300
And I confirm his excel sheet you shared (thank you) is my settings set up.
I did not see any emergency rear braking on his, either.
Old Mar 10, 2024 | 08:52 PM
longtrip68's Avatar
Originally Posted by stillruns
Imagine that. JLR won't let you back your $80,000 Defender up with the door open without bombarding you with warnings. Anyone that has done any off roading knows that opening the door to see happens quite a bit in certain instances. I am not surprised at the audible warnings but the forced park feature would chap my a$$. Sell it and get an LC.
I agree. An $80,000+ suv marketed heavily as one of the most capable off-roaders available, and they prevent you from executing very common, traditional off-road maneuvers like spotting your tire with the door open. Also, they prevent you from choosing the 6-cylinder engine AND proper 18” wheels. And even worse, if you pick up a used Defender that came with 22” wheels, you can’t even modify the rotors (cost effectively) to eventually put on 18” wheels. But you can order a 110 with Terrain Response 2, rear locker, and a built in air compressor, but it is neutered with 22” wheels.
Old Mar 10, 2024 | 11:42 PM
GavinC's Avatar
@longtrip68 When it comes to the new Defender, you're better off listening to folks who actually own/drive one. Stillruns does not own, has little to zero first hand information on the vehicle, and seemingly not a fan. You can reverse with the door open.
Just reselect reverse after the first warning and return to park. A slight inconvenience at any price.
There are a few features that seem to provide folks great hassles with simple workarounds built into the vehicle. i do share your views on LR's insane rim offering.
Old Mar 11, 2024 | 03:34 AM
lightning's Avatar
A woman in the USA (although it could have happened anywhere) got out of her Range Rover and it drove over her, killing her. Not straightaway, she got up afterwards but was fatally injured.
lt looked like she wanted to get her things out of the back before parking the vehicle.
l assume she had the vehicle in "Reverse" but with "Auto Hold" and made a mistake not selecting the park brake.
The "Auto Hold" released itself after a short time. As the door was open it knocked the woman to the floor and then the front wheel went over her.
So l imagine there was a lawsuit and the vehicles are now designed to prevent this from happening.
LR2driver
LR2
Mar 23, 2021 08:25 AM
SmithZ80
Dec 6, 2020 03:26 PM
jimvw57
Feb 7, 2017 09:15 AM
RROJ
15
Aug 26, 2010 04:38 PM
DooDer
Dec 28, 2009 09:42 PM
