Center Console Sliding Tray
Does anyone know the part number for the rubber sliding tray that can cover the cupholders or charging spot on the center console? My just deliver 22D90 didn't come with it(should it have?) and I would like it. Thanks
Check that the tray is not in the storage area underneath. There is a place directly below the cup holder/charger section where you can insert the slide out piece. Btw, it doesn’t slide. As it is rubberized, you have to lift it out of the cup holder section, rotate it 180 and insert into wireless charger section (vice-versa).
i do not know what the part number is for it.
I believe they all come with this cover but typically it seems most people stow it away. I put mine inside the armrest but oddly it's just tall enough to where it barely closes unless you lean it and then it takes up more space in there than it otherwise would. I might throw it in the glove box instead. It would be handy if you're eating in the car though to keep the crumbs out, but then if you have a drink in there forget it.
The other thing I noticed is the right-side cupholder fits my large coffee and the left side is too tight, is there an option to purchase another 'insert' so both sides are the same as the larger sized one? I could probably do something with the rubber bumpers inside there so the left side isn't as snug but having to resort to a duct tape fix on week one is not exactly my first choice.
Edit, just to add to this, I figured out the workaround for the overly-snug left cupholder. I found that I could press in the left rubber bumper completely so it's concave. Works perfectly. Sorry for derailing the thread a bit.
You learn sometime new every day! Thank you.
