Change signature graphic?
Old Sep 20, 2022 | 12:39 PM
Rcf75's Avatar
Default Change signature graphic?
I placed an order for a Defender 130. I am reviewing the build, and realizing that the dealer does not appear to have picked up the black signature graphic - I ordered white vehicle, but wanted that signature graphic blacked out. Does anyone know if this signature graphic can be replaced with a black version after delivery? Thanks in advance!
Old Sep 20, 2022 | 03:17 PM
inater's Avatar
Are you talking about the black lettering of DEFENDER on the hood and rear?
Old Sep 20, 2022 | 03:25 PM
Rcf75's Avatar
No, I am referring to this section of the greenhouse, which LR refers to as the “signature graphic” that comes standard in body color or black for $200.
Old Sep 20, 2022 | 03:30 PM
inater's Avatar
Ah ok. I know that powerfulUK makes these stickers but not the same as it being all black.
https://www.powerfuluk.com/vehicles/...nder-l663.html
Old Sep 20, 2022 | 04:17 PM
CombatNinja's Avatar
You can change it out. Way cheaper and easier to just wrap it in vinyl of your choice.
Old Sep 20, 2022 | 09:07 PM
Royalist's Avatar
If you call the dealer you can have it changed, so long as you are not past the "last amendment possible" date. The only way to get it gloss black, is if it has the black contrast roof.
Old Feb 5, 2024 | 06:44 PM
ColonelBlood's Avatar
Default Custom lettering on hood
Anyone know where to buy it to replace defender lettering? I want my company name....
Old Feb 20, 2024 | 12:18 AM
longtrip68's Avatar
Lucky 8 sells a Signature Graphic delete kit. Which tells me it can be removed (held on by double sided tape apparently and some alignment holes). If it can be removed, that means it can be either replaced with the color of your choice, painted, or wrapped. So, I wouldn’t sweat it too much.
Old Feb 22, 2024 | 03:52 PM
Default Vossen 23x10
Best!
Old Feb 23, 2024 | 06:59 AM
Mike_F's Avatar
I really didn’t like the squares either. I covered mine with the Powerful UK vinyl kit. Easy to install. I actually like the body-color border it leaves more than I thought I would.
