Coil spring lift kit
Old Feb 7, 2022 | 07:18 PM
sarek's Avatar
Default Coil spring lift kit
Pre order for lift springs for coil equipped d90 and d110 is now available. Front coils provide 1.5 inches of lift with 250lbs of added load. Rear coils provide 2 inches of lift with 750lbs of added load. The stock coils were tested to provide correct rates for lift springs. Stock ride quality is maintained! Click on link below:
https://www.etsy.com/listing/1160897916/2020-new-defender-lift-springs-made-to?utm_medium=SellerListingTools&utm_campaign=Shar e&utm_source=Facebook&share_time=1644252117000&utm _term=so.slt
below photo is our 90 that already had a 4 inch subframe lift with 35 inch tires and stock coil springs. We added the custom coils to test which brought the lift to 6 inches (Pictured). Coil spring lift didnt noticably change the drivability.
Old Feb 7, 2022 | 10:12 PM
Mark1107's Avatar
Stunning Ralph! Great option!!!
Old Feb 8, 2022 | 10:42 AM
gb_junkie's Avatar
This is great @sarek ! The more I look at the height of my coil sprung 110, the more I'm wanting just a little lift for piece of mind. Assuming the stock shocks are fine taking the extra height?
Old Feb 8, 2022 | 10:49 AM
Drewes's Avatar
Would we be able to see what an otherwise stock Defender looks Iike with the lifted coils? Personally I'm interested in pics of the #90 and #110. The shown #90 with 6" of height looks pretty tall to me, as someone who plans on driving the truck nearly daily. Obviously I can see the benefit when rock crawling, but for day-to-day use it's out of the question.
One branch-off that I'd love to see after modifications like these: Answers to common questions.
  • What size wheel/tire can you specify and run after completing the coil swap?
sarek's Avatar
Absolutely no problem with the stock shocks. It is as simple as replacing your stock coil springs with these, performing a four-wheel alignment, and aiming the headlamps.
Old Feb 8, 2022 | 11:00 AM
sarek's Avatar
I completely understand that photos of my test vehicle will not provide an accurate visual. I ordered these coil springs special made and had to fit them on my truck to determine if everything works well. Hence the reason why I only have photos of it with a subframe lift already installed. As soon as this pre-order is done, I will have plenty of photos of stock height vehicles that only have the coil spring left. As far as 6 in being excessively too tall, I have also added a photo of my truck next to an Nas d90 with 2 inch lift and 33 inch tires for reference. I have confirmed with measuring that the expected lift from the springs is going to be very close to the specs given. Every vehicle may be slightly different just by how it is equipped and how much weight is being put in it. I went taller in the rear with more load rating so that with the vehicle unloaded, there will be some rake. But as soon as you add load or hook up a trailer you shouldn't have to worry about the rear squatting. And to reiterate, my truck with or without these lift springs rides the same.
Old Feb 9, 2022 | 08:21 AM
sarek's Avatar
Please PM me if you would like to pre order. Ignore the link on my 1st post as it is no longer active.
Old Feb 9, 2022 | 11:26 AM
Drewes's Avatar
When are you accepting pre-orders? Is there a deadline for the order?
Old Feb 9, 2022 | 02:58 PM
sarek's Avatar
we are accepting pre orders now. Once we sell 10 pre orders, then we order. So there is a deadline in a way.
Old Mar 11, 2022 | 01:31 AM
Drewes's Avatar
I'm still interested in these springs. Is there an update that can be shared? Did you reach pre-order number yet, or are you still collecting buys?
Have you considered doing an installation video on this? That would really help those of us interested, I'm sure.
