Cutting the flat plate off the expedition roof rack?
Old May 15, 2022 | 06:09 PM
GrouseK9's Avatar
Yep, both of them are OEM Expedition Racks from Land Rover.
Old May 15, 2022 | 09:23 PM
deadlast's Avatar
@GrouseK9 what did you paint the roof with? I like the textured roof.
Old May 16, 2022 | 07:47 AM
GrouseK9's Avatar
I think he used Rhino lining on the roof (Link). He wanted a white look and went for it. He plans to keep it for a LONG time, so didn't really care. There were a LOT of vehicles at SCARR that just covered the entire vehicle with the stuff.
If you pay attention to the third pic, he also lost his front wheel extended arch on one of the trails. I talked to him about a story I heard just that morning. Someone else did the same thing and just bought a replacement. Unfortunately, his has a bit more panel creases where the arch won't cover so is going to have to do a little work first. He was debating replacing the panel or just beating it out a bit. I suspect he will / did go for the later.
Old May 16, 2022 | 07:52 AM
deadlast's Avatar
Originally Posted by GrouseK9
I think he used Rhino on the roof. He wanted a white look and went for it.
I would a local place that will do roof wraps. I will probably get mine wrapped. Just waiting on delivery...
Old May 16, 2022 | 07:55 AM
GrouseK9's Avatar
It will be a LOT less permanent. I suspect that Rhino (or Raptor, similar stuff) would be EXTREMELY difficult to get off if you wanted to go back to normal paint. It's likely not as easy to remove as a popcorn ceiling!
Old May 17, 2022 | 03:25 PM
DonMitsu's Avatar
This is awesome and am on their website this morning poking around. What size did you buy ?
I don't remember, but if you call or email Brad, they have sold several to Defender owners, as we all have the same issue with the expedition rack.
Old May 17, 2022 | 11:53 PM
nashvegas's Avatar
I put an expedition rack on my 110 last weekend.
Very quiet. No wind noise other than a very faint bass rumble above about 70, otherwise I cannot hear it. Really! When I open the pano roof at highway speed there's a bit of buffeting that goes away when the windows are down slightly in the cabin.
I had mentioned wind noise to the dealer and asked to make sure I got the latest part revision (not even sure if that is a thing but... I didn't want old stock from 2020 or so). Dealer told me one key to minimizing wind noise is ensuring those rubber ribs up top on the crossbars go all the way to the end under the black metal surround... no idea if that is bunk advice or not. I did do that but ... I was pleasantly surprised as I was expecting wind noise akin to my safety devices safari rack on my D2 etc etc. But anyway just throwing my hat in the ring of "no discernible wind noise beyond a deep bass rumble" and I've had it up to 95 with this thing on..
I'm sure I'll screw it all up when I start adding the mounts and gear up top lol
Old May 18, 2022 | 08:35 AM
GrouseK9's Avatar
Good point @nashvegas . It's best to keep those (or some 3rd party) in the tracks when not in use. I actually have cut mine up so that I cover as much as possible when I have things attached up there.
Old May 18, 2022 | 10:32 AM
GavinC's Avatar
The rubber strips make a big difference.
When I first installed mine, I did a test run with just one strip removed. Just around the neighborhood at residential speeds. A lot of whistling noise even at low speeds.
With the strips, all is well.
The other thing about making sure to tuck the ends in is that when you go to make cuts for various mounts, the maximal length of strip allows a little wiggle room when you've removed maybe an inch or so. (Later on if you decide to remove/replace whatever thingy was mounted there)
Old Feb 14, 2025 | 06:12 PM
tK$8P63IHYUvB61's Avatar
Im not sure what you are talking about with noise but the noise level is rediculous. What a complete waste of money and now I'm having to try to fix it. Worst product ever.
