Dash cam on a USA build
For those of you still following this thread, PowerfulUk recently posted some harnesses that plug into the JLR camera harness location to allow you to install Garmin & a couple other DashCam types. Basically, you junction into the same harness and it runs the same power to your preferred dashcam up there. This was a game changer for me.
_Allegedly (12-23-2021)
I did the BlackVue and it plugged right in. Getting the panel out with the sunroof controls is fairly easy if you watch Simon's video that shows the spot to pry without crushing the headliner. Otherwise it's trial and error and it's easy to leave a permanent pry mark.
Same! They got it to me in Florida in 4 days.
Simon's video was great for the overhead panel removal and wire harness install. I did change one thing from his install though. I used a 3ft zip tie (designed for AC duct) instead of his plastic ruler because I had a pack of them already and a ruler seemed a little stiff.
I never saw anyone else post up rear camera instructions so I actually did that a few weeks ago. I hope it helps and, if you have questions, happy to try to answer.
Fwiw, I'm extremely picky about making sure you can't tell anything was done and the only bit of "damage" was when I tried to use a spudger to pry the rear door card off. It left a 1mm size indent in the paint which is surprising considering they're pretty soft. Definitely need to use fingers with a good set of soft gloves to pop that panel off.
https://landroverforums.com/forum/20...camera-109588/
Here's the final install. The only quirk is that the front camera is behind the line in the factory tint so you can see that split in the image. I'm fine with it because I only use this in case there's an accident. People using it to record thier driving for social media or whatever would want to move it to the right to get fully behind the tint or get a different camera that fits more to the left.
johnsonmc2000 (12-26-2021)
https://www.powerfuluk.com/vehicles/...nder-l663.html
Is that factory tint the "solar attenuating windshield"? My 22 does not have that cut-out. I am looking at installing a dash cam and initially ruled out the BlackVue because of that cut-out but now it's back on the list. I just have to decide between the Land Rover dash cam and the BlackVue (Land Rover sent me a $300 gift cert so the LR cam is about 1/2 the price of the BlackVue).
Would it be possible for you to post pictures of your windshield from further back? Both inside and out? I'm hoping to get an idea of how much the camera intrudes into the passenger's line of sight.
Thanks
Hi Allegedly,
Thanks
Thanks
Mine has the thermal comfort mark.
Idk if that helps but I can check my window sticker or can give you the VIN if you want to call LR and see what mine is. It's not something I specifically specced but I have a '22 X-Dynamic HSE.
_Allegedly (04-14-2022)
