Defender 110 7 Seater (with 3rd Row Seat)
Old Oct 8, 2023 | 08:23 PM
AAJR's Avatar
Default Defender 110 7 Seater (with 3rd Row Seat)
I am thinking of relocating my tools (jack, etc.) by buying and installing the foam insert (I believe it is part LR167249, but would appreciate any input) from a 110 7 seater (with the 3rd row seat), and could use some help.
If you have a 110 7 seater, could you post a picture of the foam insert that is behind the third row seat under the floor panel, that holds the jack, and perhaps also post the front to back dimension of the foam insert (see picture)?
I would like to confirm how much space it takes up (front to back). I believe this insert is the same for the coil spring version and the air bag suspension version, but hopefully you could also mention which version you have.
Removing the large foam insert that comes with the 5 seater and replacing it with the 7 seater foam insert should gain a ton of space under the rear cover (specially for cars that do not have a hybrid system under the cover).
Thank you in advance.
Alberto
Sorry for the poor picture, but I cannot locate a decent one.
Old Oct 8, 2023 | 09:12 PM
GavinC's Avatar
Foam is 9” front to back.
air suspension
MY22 110 P400 SE
seven seater.
Old Oct 9, 2023 | 01:21 AM
AAJR's Avatar
air suspension
MY22 110 P400 SE
seven seater.
Thank you very much, I really appreciate it.
Alberto
Defendit..
Apr 27, 2023 06:50 AM
Vikep
Oct 18, 2021 08:27 AM
PatriotDefender
May 9, 2021 05:07 AM
Ryu2021
Mar 16, 2021 10:19 PM
Paul64
May 22, 2007 01:07 PM
