Defender 90 Service Rant
Old Aug 18, 2022 | 12:26 PM
  #21
Royalist's Avatar
Originally Posted by BlacMacJac
related question: wife took her '22 defender due to a software update getting corrupted and it locked up her infotainment screen. while there it was decided to do an oil change, and resulted in a $500+ bill with an additional $80 for an ethanol kit. Is this normal? And are oil changes on these things something I can't do myself at home? Not that I expect a "$30 Jiffy Lube special" but was startled the invoice.
2nd Gen Defender (2020-2023.5MY) Maintenance Schedule for regular oil changes under most conditions is every 21k miles or 2 years (which ever comes first) for the P300 and P400. If you’re changing oil every 5-10k miles, it’s a waste of oil and money in my opinion. Read the owner’s manual.
These are BMW-sourced engines tuned to LR’s Ingenium specs, this isn’t the 70’s anymore where an oil change is needed every 3k miles. If you’ve been following the schedule, great. A few hundred bucks for an oil change ain’t bad if spread out like that.
No idea what an ethanol kit is though.
Old Aug 18, 2022 | 01:54 PM
  #22
jusmax88's Avatar
Hope you’ve done your research on Land Rover timing chain issues before giving that advice
Old Aug 18, 2022 | 03:11 PM
  #23
MattF's Avatar
No way I'd EVER go that long between oil services. Most of these long intervals proposed by the manufactures are for marketing purposes. In the Porsche and Audi communities there have been numerous examples of failures related to following oil service recommendations. The IMS issue with the M96 engine one example. Materially higher failure rates in cars that followed the suggested oil service intervals.
It's cheap insurance also.....
Old Aug 18, 2022 | 03:42 PM
  #24
DoctorofRocks's Avatar
Here's that section of the invoice - the "ethanol kit" was explained to me as some sort of "cleaner" (?) and honestly I was having such a hard time processing the $500 for the oil change I didn't really listen to that well enough to honestly judge it.
I talked to my sales contact that I've know for 15+ years and he admitted it was expensive, but on par with other dealers. he advised that if I do future changes to make sure I "keep receipts" so that if there are any warranty issues later - Land Rover will want documentation that I performed the work. (I wonder if that raises questions about doing the work myself?)
They are ripping you off on multiple levels here.
First they are charging for 10l of oil. The P300 takes 7l, the P400 takes 8.8l and and the v8 takes 8l. Then the labor charge for the oil change is included in the parts total "Perf oil service" for $60 which is about right for the 15-20 minutes it takes.
So where the other hour of labor at $252 comes from is anyone's guess.
Please publicize which dealer this was so we can avoid them
Old Aug 18, 2022 | 03:48 PM
  #25
jusmax88's Avatar
I might just be overly cautious but 10K miles/1 year is the minimum I’d do and that would only be for a leased car.
Old Aug 18, 2022 | 04:55 PM
  #26
Royalist's Avatar
It's not advice, it's straight from LR, that's their language. I had no issues with mine going almost that far. Most people don't keep Defenders, LRs, or any new car for that long anyway.
Old Aug 18, 2022 | 08:43 PM
  #27
MattF's Avatar
but your opinion was people would be “wasting their money and oil” changing earlier than manufacturer recommended….
Old Aug 19, 2022 | 09:43 AM
  #28
Royalist's Avatar
That’s right, that’s my opinion. I wouldn’t consider that “advice”, I’m not a mechanic nor an engineer. People will follow anything in an owner’s manual, but soon as they talk about oil changes, everyone’s an expert.
Old Aug 19, 2022 | 10:01 AM
  #29
jusmax88's Avatar
Ignore the evidence if you want, but it’s out there. Also, no one is saying your car will explode at 20,000 miles if the oil hasn’t been changed. Many cars will last 200,000+ miles with the recommended service interval, but many will not.
You said you don’t keep cars long, I typically haven’t either (this will be the first exception if all goes well) and have stuck to recommended service intervals, so I totally get it. But if anyone plans to keep this car for more than 4 years, imo it would be best to increase your odds of a favorable outcome.
cookjw
Aug 14, 2022 05:46 PM
BulldogDefender
Apr 20, 2022 11:52 PM
hoss_vw
Jan 12, 2022 11:40 PM
nashvegas
Jan 5, 2022 11:54 AM
brfan1
Aug 30, 2017 06:12 PM
