Defender X Dynamic - 20 vs 22 inch wheels in NY?
Hi All
I'm about to place an order for a new 2021 Defender X-Dynamic 110 HSE. Very excited to do so! Because of timing, I am going to be sticking with dealer inventory instead of custom ordering it.
Here's my question.
The base X-dynamic comes with 20" 5098 5 Spoke in Satin Dark Gray -- and they look great to me. So do the other 20 inch 5095 Gloss Dark Gray with Contrast Diamond Tuned Finish for $700 extra.
But a lot of cars on lots here in NY / NJ have the 22" 5098 5 spoke gloss black for $2000 extra.
Other than the way it makes the Defender look -- is there any reason for me to splurge and get the 22' inch wheels? Here in the NYC area and suburbs the roads are ok. Oh yeah, and there will likely wont ever be any off-roading with this car. it's just a nice rugged alternative to all the other german / swedish cars/SUVs we have had. OR will this be a harsher ride and more maintenance for the wheels? and more expensive to replace?
Let me know your thoughts,
Thanks
Here's my question.
Thanks
i was thankful to come across the spec i bought with the dark 20" wheels. while the 22's look good you cited the downsides. cost & smaller sidewall which results in harsher ride and more susceptible to damage from potholes & off roading. i feel like my 275/55's give the bare minimum protection for sidewall flex for the way i use the vehicle.
on
I had a dodge ram that had 20's stock and I upgraded to the srt 22' wheels after a couple of years. I did not notice a change in ride quality. Appearance wise it was a big improvement. The truck was not used for anything off road.
Here is an article linking the effects of wheel size difference
https://www.caranddriver.com/feature...-wheels-tires/
I ordered the grey 20' wheels for my defender fwiw.
proportionally the 22’s actually fit the truck better. the 22’s do have a some what beefy side wall at 45 so potholes shouldn’t be a huge issue unless you hit them at 80 mph
the defender crowd is divided and leans heavily more in the off-road category. So you will get the off-road comments more than not. but the new chassis is a blend of urban comfort with super abilities. so use the car the way your wallet tells you .
i am not a fan of the 22 design and only reason i wouldn’t spend the extra money as i would replaced them.
i replaced my 20’s with aftermarket 20’s with bfg k02’s with heavy influence from off road friends. my defender will prob never see the dirt it was built for but it does see snow a lot. So if anything i would need a more all weather tire.
that being said i regret my purchase of my 20’s and will be moving back to some 22’s with AT tires
Hi All
Here's my question.
Thanks
Here's my question.
Thanks
Hi All
Here's my question.
Thanks
Here's my question.
Thanks
Ride quality is great and I just came out of a RR long wheel base.
