Digital Dash Shortage
$14k more for analog gauges, faux galvanized trim, and a wrap that simulates spot welds and rust bubbles.
Overdrive package is in tight supply so you'll see if you get it when you show up to pay.
Models equiped with the Authenticity Package (double-clutch and exhaust injection into the cabin) are stuck at port because it pops out of gear when you shine a flashlight at it.
![](https://cimg2.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1370/screenshot_20210818_225718_3c85226a1df3ce3a859a79459aa23a5e161c8de8.png)
The following 6 users liked this post by _Allegedly:
catman (08-23-2021),
DakotaTravler (09-08-2021),
Eitan (11-17-2021),
Magnumforc (08-24-2021),
milehi (08-26-2021),
and 1 others liked this post.
Peterbilt has an assembly plant just North of me. Near the plant there is a giant field full of new trucks. They are parking a truck and removing a particular chip, getting the next truck from the plant with same chip, parking in field. Hundreds of trucks driven to the field using the same chip. Crazy times for sure.
I have a 2022 Defender 90 that should be at the Dealer this coming weekend. I did not order it. It was already in transit and I jumped on it before anyone else did. I have seen the build sheet for it and it does say on the build sheet "Interactive Driver Display." That mean I for sure DO have the full digital screen behind the steering wheel on mine?
Edit. Sorry, i see that you actually posted in the other thread as well. But, I don't think there has been any updated guidance to the dealerships. Maybe your sales rep is trying to navigate this. FWiW, I don't think the dates mean much as my order showed as being close to US Port up until the day i found out it hadn't even been built.
I’m intrigued by your comment. In what way do you think any car manufacturer could plan well given the perfect storm that’s been going on for the last 18 months? It’s certainly not going to end soon either. And when China marches into Taiwan we will all be screwed for years to come.
I see this as the opposite. The analogue/digital display requires all the software and chips that the full digital display does plus the analogue/digital combo actually has additional mechanical/moving parts that have a history of failing. it's not like the analogue/digital combo doesn't have a screen and I would wager both displays actually use the same software. From a maintenance perspective, the full digital display should theoretically be easier to maintain. I can only think that the cost of larger display itself offsets the cost of the mechanical gauges, which would explain the difference in price. I guess the downside of the full digital display would be that it's a single point of failure whereas the analogue gauges would still most likely work even if the screen did not. It will be interesting to see which breaks first, the gauges or the screen.
