Switching off auto hold does not completely disable brake hold, it will still hold if you press the brake pedal a little too hard. You can remove brake hold completely with the GAP tool.
Yes, but it's not that easy to reactivate, at least for me.
I've never tried to reactivate it. What issue did you run into?
I meant if it's off to activate with pedal again, I know it's possible but not always easy manually, I have it OFF in the menu, not in CCF.
Pedal trick temporary overrides the setting.
