Enhanced engine sound de activation
Old Feb 25, 2024 | 10:53 PM
  #21
Tasmanie's Avatar
6th Gear
@BruBelg So do you think that unplugging the factory Subwoofer and adding another sub and a dsp will stop the “fake engine noise” when upgrading audio?
Old Feb 25, 2024 | 11:22 PM
  #22
Ehloo's Avatar
the fake noise is programmed into the meridian digital sound processor so it won’t go away if you use any factory source through pivi.
i had mine turned off remotely. jlractive mailed me their laptop, remotely logged in and 10 mins i was done.
if you are in the states or UK it’s an easy fix
Old Feb 26, 2024 | 02:43 AM
  #23
Pangea123's Avatar
Originally Posted by BruBelg
it also disappear is one window is slightly open…
Could you use this to your benefit? Can a body shop open a rear door and mess with the motor/ window positioning so it still closes but the motor thinks the window still has some “travel” left?
FWIW when I got my audio upgraded, the shop fully disabled the OEM subwoofer and installed a custom sub in the trunk as the solution.
I only got to enjoy the upgraded audio for 2 days until some idiot totalled the rig in the rain (!!) but that’s another story for another day.
  #24
BruBelg's Avatar
4th Gear
Hello
just to be clear on my set up, I do have the DSP + SW Amp and Additional SW... (and the noise, unless the SW is unplugged...)
the original SW is still connected to the car AMP
Old Oct 19, 2024 | 08:00 PM
  #25
High Desert Dog's Avatar
Hi, I have a 2024 Defender that I had a new DSP, speakers and amps installed to improve on the miserable stock Meridian system. It all sounded great until I started the car and stepped on the gas. To my horror the fake engine noise was about 4X worse. It was so bad I turned off the amps until I’d learned about JLRActive who came to my rescue, sent a laptop to me and in about 10 minutes the fake engine noise was gone. JLRActive has several packages starting at $600 and topping out at $1K. On the surface this seems like allot of cash to kill the stupid fake engine noise feature, HOWEVER there’s a bunch of very cool useful stuff already programmed into the car but hidden from all but the highest dollar purchasers of the car. JLRActive turned on a bunch of features that totally transformed my car and its performance. Looking at it this way $1K is a smoking deal. Also my experience with JLRActive was 5 Star. Can’t say enough about how good this all is.
Old Oct 20, 2024 | 06:11 AM
  #26
jwilliexd's Avatar
Does the P300 also have the fake engine noise or is it a “feature” limited to P400 and above?
Old Oct 20, 2024 | 07:22 PM
  #27
Defendit..'s Avatar
Yes it has.
2 Multicans needs to be changed
584 PTSQ NLI change to Not fitted
585 NGPTS Q. change to Not fitted
You'll need a GAP IIDtool V4 to do this
jilikits994
Apr 17, 2025 01:59 PM
elektron
Oct 20, 2024 08:18 PM
MotorCityRover
Range Rover L322 (3rd Gen)
Dec 16, 2022 08:43 PM
white79au
Range Rover Evoque
May 18, 2022 05:14 AM
Atticus_6147
Oct 19, 2017 12:36 PM
