Expedition rack and ladder questions
Old Oct 27, 2020 | 05:22 PM
Shodan01's Avatar
Originally Posted by Guapo
How did you run your wiring for the light bar?
Battery to circuit and took two black wires through the A-Pillar and up the crack that goes to the inner roof rack. I bought small rubber seal that coves it completely, then up the side mount of the roof rack and over. From the circuit inside, I took it across the inside of the hood, under all the plastic, and took a positive through the side A-pilar, inside the door and into the cubby area where I mounted a round switch- Its not perfect but I couldn't find a port into the cabin from the engine bay....
Old Oct 28, 2020 | 10:15 AM
Guapo's Avatar
I'm good with all of the wiring other than getting it to the roof rack. Can you send a few pics of it above the a pillar?
Old Oct 30, 2020 | 04:11 PM
Shodan01's Avatar
Black helps, but you'll see in the crack above the pilar a wire fit down in there - I put two separate wires instead of one combine.
As you get towards the rack, I used 2inch gloss black vinyl to cover the wire to the rack
Old Oct 30, 2020 | 08:45 PM
Guapo's Avatar
Thanks for sharing. Looks really clean. I have the white roof which complicates things.
Old Oct 30, 2020 | 09:36 PM
Mark1107's Avatar
We love our fully loaded P400 HSE Explorer pack. The ladder is great! My winch is in a box in the garage I’m waiting on Powerfuluk to YouTube the install instructions so I can tackle it.
Old Oct 30, 2020 | 10:06 PM
RSNSG4's Avatar
Very very nice! Question, did you install the tube side steps or did the dealer?
Old Oct 30, 2020 | 11:21 PM
Shodan01's Avatar
Buy white wires - or try black - it might look like part of the separation.
Old Oct 31, 2020 | 07:29 AM
4Corsa's Avatar
Any thoughts on the ladder? Curious to see it open and in different stages of use. Thoughts from people who’ve used, etc. I have until 11/9 to change anything on my build.
Old Oct 31, 2020 | 09:40 AM
DonMitsu's Avatar
Not sure if this helps, but it has been thoroughly kid tested lol
Old Oct 31, 2020 | 12:18 PM
avartanian's Avatar
Ladder is great, completes the look. I highly recommend it.
