Expedition Roof Rack T-slot bolts?
I recently got the expedition roof rack for my 110. I’m looking to find some t-slot bolts that will fit on the roof rack. For now I’m trying to mount my recovery boards to the roof rack and I found some 3/8 x 6” bolts that could fit in the slots on the roof rack and also fit my recovery board but I will need to shave 1.5mm off in the height of the bolt top so it can fit in the slot.
Have you done any diy mounting on to your roof rack if so can you share any tips or pics?
I don’t have an answer for your question but hoping to piggy back on this thread since it’s about the roof rack. I have a 110 coming in soon with rack and ladder. But it doesn’t have the side tool box on the right side. Is it true the side box would have needed to be installed before installing the rack? If I wanted to install the side box, could I get away with a partial uninstall to get the box grabbers on the rails?
worth watching all his defender videos, he shows how to install virtually every bolt on defender accessory available
The Front runner tie down rings will work in the slots.
Tie Down Rings For Drawer System - by Front Runner SSCA047
Tie Down Rings / Eye Nuts For Drawer System - by Front Runner | Front Runner (frontrunneroutfitters.com)
The following 2 users liked this post by johnsonmc2000:
Craig_RRS2013 (10-25-2021),
Huc (08-09-2022)
this video should answer your questions https://youtu.be/OcuC6puzO_o
Installing the side box require removing the rack. I was also told that installing the ladder would require removing the rack, otherwise i would have bought just the ladder and gotten a rack later. I wanted the front runner rack but 2 of my attempts to order it got delayed because they were out of stock ( 2 different online stores listing them in stock until i ordered :-/ )
@sebastienb Just wondering if you ever found the T-slot bolts you were looking for?
of the suggestions I’ve seen online. Once I do I’ll update this thread.
