Flickering map
Old Dec 7, 2020 | 09:55 PM
Mark M's Avatar
Default Flickering map
The map in my instrument cluster was flickering today. Seemed to work fine during a call or when changes to the dash were happening.
during normal driving the flashing of the screen was very distracting.
first time since owning for 2 weeks now
ideas?
Old Dec 7, 2020 | 10:11 PM
SlowRider239's Avatar
Bring it to the dealer if it continues to do it. I would let them fix it.
Old Dec 8, 2020 | 07:42 AM
stillruns's Avatar
Nonsense. It’s an $80,000 Defender made by JLR, must be a hallucination.
Old Dec 11, 2020 | 05:31 PM
Mark M's Avatar
Narrowed it down a bit. Seems to happen when making a call. Seems like apply car play is interfering with the map between the two dials.
Doesn't happen with a full screen map or single dial. Just the 2 dial with a map setup.
So strange
Old Jan 3, 2021 | 04:44 AM
1availablelight's Avatar
I had a similar issue with flickering and new iOS. Very annoying. Try this: disconnect CarPlay. With engine on, hold the radio power button down for 20 seconds and let Pivi do a soft reset. Reconnect CarPlay. If that doesn’t work you can also try a hard reset. Disconnect CarPlay. Hold the radio power button for 10 seconds, once Pivi goes blank turn off car and lock doors. Let the Defender sit for 5 minutes. Start engine and reconnect CarPlay. This should be addressed in future OTA.
Old Mar 2, 2021 | 12:53 PM
Defender2A's Avatar
4th Gear
Had my 2021 Defender 5 days and map flicker started w/ phone plugged in. Great start.
Old Mar 2, 2021 | 01:31 PM
Mark M's Avatar
Default Map
I had the same issue but found a better quality phone cable fixed the issue
Old Mar 2, 2021 | 05:09 PM
Defender2A's Avatar
4th Gear
Dealer told me to use the Apple cord b/c they are made for data transfer. I did use it - the new Apple USB C cord. Still flickering. Going to try the reset suggested above
Old Mar 2, 2021 | 05:41 PM
tictalk67's Avatar
Lock the car overnight with the Fob, it will take care of the problem for a while then, repeat as needed!
Old Mar 2, 2021 | 07:38 PM
Bukmar's Avatar
I’ve got the same issue...seems to happen when changing tracks on apple car play.
