Front end protection question
#21
Why not just remove the factory plate and powder coat it? I figured that would be easiest and cheapest option.
MattF (10-20-2022)
#22
I too started down that road, but its two weeks turn around, and 300$ I can buy the aftermarket for not much more, and according to its site is anodized not powdercoated which will be much more durable in the winter.
If I cant get a definitive answer, Ill likely go the PC route, but its worth asking around first.
#24
#25
Glad it helped. If you do decide to go for the aftermarket one, you'll probably change out those bolts anyway. Like me, you'll want black along with black washers I suspect, the aftermarket are silver as you can see but also a little short. I'm off to find some M10x35 in black. Good luck with the install.
#28
#29
I was able to source some longer black finishing bolts and washers for the black aftermarket skid plate - looks much better. The supplier has this information now so hopefully you'll get some in the new kits. Simon at PowerfulUK will include instructions for the U-bolt access cut out holes as an alternative to trimming away your rear shield. I did grind my washers down and this helped me cinch the brackets in to just the right place. Have fun.
#30
