Front end protection question
Old Oct 20, 2022 | 05:20 PM
  #21
Lnberger's Avatar
Originally Posted by Paradigm
Does anyone here know if the aftermarket easy fit lines up with the oem holes? I have the silver plate, but want to swap it for the black one, but Im not sure if the aftermarket requires fitting their brackets.
​​​Why not just remove the factory plate and powder coat it? I figured that would be easiest and cheapest option.
Old Oct 20, 2022 | 05:51 PM
  #22
Paradigm's Avatar
I too started down that road, but its two weeks turn around, and 300$ I can buy the aftermarket for not much more, and according to its site is anodized not powdercoated which will be much more durable in the winter.
If I cant get a definitive answer, Ill likely go the PC route, but its worth asking around first.
Old Oct 20, 2022 | 05:52 PM
  #23
Paradigm's Avatar
This is very helpful! [heads to garage]
Old Oct 20, 2022 | 06:06 PM
  #24
Paradigm's Avatar
Looks like they do in fact line up. The only thing that may be different is the size of the heads on the oem bolts, but otherwise they are the same. I really wish I didnt know that they are asymmetrical now its gonna bug me. What engineer would allow such a thing!
Old Oct 20, 2022 | 06:33 PM
  #25
Vintage12's Avatar
Glad it helped. If you do decide to go for the aftermarket one, you'll probably change out those bolts anyway. Like me, you'll want black along with black washers I suspect, the aftermarket are silver as you can see but also a little short. I'm off to find some M10x35 in black. Good luck with the install.
Old Oct 20, 2022 | 07:41 PM
  #26
NoGaBiker's Avatar
Originally Posted by vintage12
355 ftw.
Old Oct 20, 2022 | 09:56 PM
  #27
Vintage12's Avatar
Originally Posted by NoGaBiker
355 ftw.
Ha. Good eyes!
Old Oct 24, 2022 | 06:43 AM
  #28
Aya's Avatar
Aya
3rd Gear
Originally Posted by MattF
Nice work!
Another way to address the slight misalignment is to grind down one side of the washer on the mounting bolt a bit. That's what I did with mine to get the bolts to align.
I installed the Ez fit and was all prepared to have to file things like in the video- when I first installed the brackets I didn’t have them seated in as “low” s as possible but after a light tap with a mallet, everything fit great. Did not have to grind the washers. The two top screws (“e”) felt short but seem to be seated in well enough, time will tell. I basically trimmed off all the plastic because I managed to completely rip both sides in half backing up a bit in some mud a month or two ago 😂
Old Oct 24, 2022 | 02:08 PM
  #29
Vintage12's Avatar
I was able to source some longer black finishing bolts and washers for the black aftermarket skid plate - looks much better. The supplier has this information now so hopefully you'll get some in the new kits. Simon at PowerfulUK will include instructions for the U-bolt access cut out holes as an alternative to trimming away your rear shield. I did grind my washers down and this helped me cinch the brackets in to just the right place. Have fun.
Old Oct 25, 2022 | 09:50 PM
  #30
MistaCh0w's Avatar
can you share a link to the bolts and washers you used?
