Front Eye bracket and Finish
Old 05-01-2021 | 02:47 PM
N E WHR's Avatar
Default Front Eye bracket and Finish
The following 2 users liked this post by N E WHR:
A Faceless Man (05-01-2021), Ludders54 (05-02-2021)
Old 05-02-2021 | 02:51 PM
Defendit..'s Avatar
Default Aftermarket.?
Instructions & Powerfuluk.com showed a complete new under bracket
LAND ROVER ACCESSORY FITTING INSTRUCTIONS
edit - found it: chinese counterfeit / copy. Instead of Belgium made thick Alu and nicely designed bracket.
i will do with my mod untill I have the funds for the original. ( will make some changes whitin a few weeks and share)
Old 05-02-2021 | 05:03 PM
N E WHR's Avatar
Reply one,
the OEM bracket on truck nor the Tow Eye removed.
Old 05-03-2021 | 06:44 AM
Defendit..'s Avatar
Maybe you don't understand.
You buy aftermarket / copy parts from China. Why did Landrover decided not to produce them there as cheap as possible ?
Because there went a lot of reseach and designing to develop this product It need to be a heavy duty part, and as you can see on the video from Powerfuluk.com
the under bracket alone is 4,75 kg, plating of undershield is 5 mm thick . I'am proud this product is perfectly made in Belgium.
so on your § 80k car you saved a few hundred bucks...
but remember,
​​​​Poor quality remains, while low price is long forgotten..
drcoop (11-04-2021)
Old 05-03-2021 | 06:20 PM
N E WHR's Avatar
Sir,
appreciate your comments, be aware the standard front protection of the D110 is very substandard.
Yes, despite that I agreed to purchase, to the tune of 92K.
So here is the image of substandard factory OEM front under shield.
Therefore a compromise with even the aftermarket parts is a BETTER than delivered with truck OEM PLASTIC SHIELD...
N E WHR
05-02-2021 09:41 PM
redwhitekat
04-27-2021 10:50 PM
Discorama
02-02-2020 03:12 PM
Friday Night Disco
ROAMING WITH FRIENDS
12-29-2018 06:37 PM
Quick Reply: Front Eye bracket and Finish
