Hitch extension
Old Feb 24, 2021 | 03:15 PM
smiledr's Avatar
3rd Gear
Default Hitch extension
Just bought a new travel trailer to tow behind 110. The trailer dealership removed the back tire and put in the boot when hooking up the trailer. The spare tire touches the trailer when making turns.
they recommended a hitch extension. Has anyone ever used one? I am concerned of maxing out the alllowed tounge weight.
all thoughts appreciated
Old Feb 24, 2021 | 03:51 PM
DonMitsu's Avatar
I've used a hitch extension for our bike rack, but I would also be concerned using one to tow a trailer. I'm guessing the trailer has an electric tongue jack? I would think modifying the tongue jack would be a safer solution if that's the case.
Old Feb 25, 2021 | 09:01 AM
Juancl's Avatar
I would think something like this would help with this issue:
Old Feb 27, 2021 | 09:20 AM
Tartan's Avatar
Any hitch extension will substantially reduce the allowed tongue weight. Ok for a bike rack; not ok for anything but a super light trailer. Extend the tongue of your trailer with an extension instead. You’ll want to recheck and maybe rebalance or move your axle if you do, but way better than extending your hitch.
Old Feb 28, 2021 | 12:10 PM
TrioLRowner's Avatar
Maybe return the trailer for a model which fits the Defender -- or modify the front of the trailer? I too, would not vary from the tongue length or height offset specs. noted in the owner's manual.
Old Feb 28, 2021 | 11:22 PM
Juancl's Avatar
Saw this at the track today
File Type: mov
Old Mar 1, 2021 | 05:57 AM
carlmuck's Avatar
I believe gave LR recommendations NOT using weight distribution hitches...
and, looks like 8-10 inches of extension. Gonna increase the weight on the rear "axle" probably the reason for the WD hitch, pushes tongue weight off rear and distributes it to trailer and front "axle".
Old Mar 1, 2021 | 07:33 AM
crewcabrob's Avatar
This a pretty serious set up, and while I'm sure it works great, isn't what LR recommends. To be honest, it looks like he had the hitch on a previous vehicle and decided that it would work for the Defender too. I'm sure it tows great, but long term I wonder what will happen (break) first.
On a site note; LR has been notoriously difficult when it comes to hitch weight and towing capacity. My LR4 was really a challenge and I never trusted the plugin type receiver.
Rob
Old Mar 1, 2021 | 10:41 AM
spikemd's Avatar
A small hitch extension won't throw things off much. Have you seen what people tow with these days? The towing capacity of 7700lbs is substantial and the air suspension helps keep it level. Much better than all those pickups dragging *** down the road with their springs loaded. I wouldn't worry too much.
Old May 22, 2022 | 10:48 AM
l_adrianza's Avatar
Default Electrical not working? software update?
Hi all,
I installed the towbar and electrical module and harness on my 2023 90S. Installation was easy if you follow the instructions and pointers in the forum.
However aren’t working. I thought it would be plug and play, apparently not
Any pointers appreciated.
the
