Honest discussion about longevity
#51
Maybe I’m the dummy, not the 1st time….but what’s invovled in “replace all flexible brake lines”. First time LR owner but in this modern age, did they really make a vehicle that requires brake line replacement?? Can’t be. My 2007 Hummer H2 needed brake line replacement due to rust after 15 years, I get that but 63K miles on a modern car?
WAFOX (11-07-2023)
#53
--Tucker
2023 RRS Dynamic SE P400 Giola Green (Current)
2020 Defender 110 First Edition Indus Silver (Current)
2020 Discovery HSE Luxury Si6 Fuji White (Former)
2015 RRS Autobiography Fuji White (Former)
2011 RRS Supercharged Fuji White (Former)
2008 LR2 Fuji White (Former)
#54
Wow $250 for a brake hose that's some serious profitability for Land Rover and the dealer. The brake hoses for my classic Defender are around U.K. £25 each (aftermarket) and they are pretty much the same, a flexible hose with a coupling at each end.
There's definitely an opening for aftermarket suppliers on those parts.
Tucker Woods (11-07-2023)
#55
Where is the logic in making a vehicle with brake line hoses with a 6yr / 62K mi lifespan and a $1,700+ maintenance item?
I’m not super mechanical but I was the engineer on a Navy Destroyer in the 90’s responsible for 7 gas turbine engines and trust me, all the critical hoses were stainless steel designed to last the lifetime of the engine. Come on LR.
#56
#57
The brake hose replacement was not cheap (nothing is when you have it serviced at the dealership). There are 4 brake hoses (each is a different part number) at $251.75 each. The brake fluid was $31.75 and 2 nuts were $21.90. Labor was $772.45. They subtracted 10% from the figures I just gave because I had a coupon. Braking seems important and I am not mechanical whatsoever, so I don't mind having the job done at a Land Rover dealership--plus I like getting a free loaner car (they had the vehicle for a few days). Note: In the owners manual, they recommend the brake hose replacement every 63,000 miles or every 6 years--whichever comes first.
--Tucker
--Tucker
Keep in mind 60,000 miles is roughly 100,000 kilometers. I’m willing to bet this was one of those things “lost in translation” between the U.S. and Europe. There’s similar shenanigans when looking at tow capacities. Nobody is going to build/sell a brake line that has even a remote chance of failing in a few years or 60,000 miles. The liability would be insane.
#58
You paid roughly $1,700 to replace the 4 flex lines to the calipers on a 3 year old vehicle? Wow. I won’t debate the service manual, but do you recall replacing brake lines on any other relatively new vehicle you’ve owned? I haven’t - and JLR is using the same TRW brake components as everyone else.
--Tucker
COBoarder (11-09-2023)
#59
This: "Nobody is going to build/sell a brake line that has even a remote chance of failing in a few years or 60,000 miles. The liability would be insane."
No. The liability would NOT be insane if they included that mandatory replacement in the manual/servicing specs. And, lo and behold, LR obviously did.
Now, you may be right and this might have got lost in translation. It is your car and you can gamble/bet with it based on your own experiences, but you know what happens IF something goes south. LR will point you right back to the owners manual.
Tucker Woods (11-09-2023)
#60
Our 2022 Defender 90 had zero issues. Not so lucky with our 2023.5 Defender 90.
As of today with less than 6k miles of garage pampering the 2023 has had upper radiator hose section replaced, wipers replaced and adjusted, and what definitely seems to be a defective air suspension. If the air suspension is not defective then our 2022 was, because it didn’t raise and lower on its own like our 2023 is doing.
Also our two front windows click like crazy when lowered just an inch or two.
