How to choose my Defender
Old Oct 14, 2025 | 09:09 PM
  #41
Mike_F's Avatar
Originally Posted by Tomzsix
And here is a subjective question ...........What size wheels are the most popular ?? Personally , I like the 19" . They seem more appropriate for overlanding .
Old Oct 15, 2025 | 08:42 AM
  #42
CincyRovers's Avatar
19" wheels should be avoided. I ordered mine with 19s and when I needed new tires, the only option were the OEM spec all-seasons, the junk OEM Goodyear Wrangler Adventures that came with it, or the OEM Goodyear Duratracs. Next year, BFGoodrich will offer the KO3 in LT255/65R19, so there will be another good option. The 19" tire size is 255/65R19, and the only car on the planet that has that tire size is the Defender.
If you get a P300, you can fit 18" wheels no problem. If you get a P400, just stick with 20" wheels. I put on a set of 20" wheels from an LR4 and got some 265/60R20 Falken Wildpeak AT3Ws. If you really want to, you can grind the rear calipers on a P400 to fit 18" wheels, or you can swap the rear calipers with those from a Discovery 5.
I'd personally recommend sticking with 20" wheels on the P400. Moving to a 265/60R20 gives you a slightly larger diameter that won't rub, and you still have plenty of sidewall. FYI, the maximum diameter tire you can fit on a Defender on air suspension without mods is 32.6." Coil-sprung models have more clearance than an air-sprung Defender in normal height.
disco96sd
Off Topic
31
Apr 25, 2025 12:16 PM
DonMitsu
Jul 19, 2024 10:28 AM
msgm1
Dec 10, 2022 10:17 PM
exotic ltd
Feb 10, 2022 01:24 PM
RoverNeil
Defender
Dec 25, 2007 02:49 PM
