Intercooler Replacement - DIY
Old 07-30-2024 | 01:55 PM
AVLDefender's Avatar
Default Intercooler Replacement - DIY
Has anyone replaced the intercooler on their own? Curious as to how involved of a job it is. I was told mine needed to be replaced due to a coolant leak. I searched through the forum but could not find anything.
Old 07-30-2024 | 02:49 PM
nashvegas's Avatar
P400 right? Instructions attached from the JLR workshop manual. I have not done it myself.
PS - You can download P300 and P400 workshop manuals here btw - someone hosts the files.
https://landroverforums.com/forum/20...0-p400-109129/
Make sure you select "view table of contents" when opening in PDF viewer program so you can see the sections.
JLR calls what we'd call an intercooler the "Charge Air Cooler" . It sits right on top of the motor -- should not be that difficult. But draining / vacuum filling coolant is somewhat annoying.
BTW -- So someone told you that the air to coolant intercooler is leaking internally or externally? Just curious. Had not heard of intercooler failures. This might be where all of our mystery missing coolant on the P400's is going if it's an internal leak hahaha.
The following 2 users liked this post by nashvegas:
Vadiable Paradox (07-31-2024), WAFOX (08-03-2024)
Old 07-30-2024 | 04:54 PM
Super helpful! Thank you so much for the info and links.
You are correct P400, I should have specified.
I brought it to the dealer after smelling coolant and finding a low reservoir, with no obvious source of a leak (common story!). They found that the O rings in the turbo were leaking and the coolant was leaking internally on the intercooler.
POPTOPP
07-16-2024 08:56 AM
grew
12-20-2022 03:40 PM
drowssap
02-10-2012 08:08 AM
standonit
07-12-2011 12:55 AM
JBEGIN
12-10-2008 05:37 PM
Quick Reply: Intercooler Replacement - DIY
