Interior Bolt color change
Old Feb 7, 2025 | 12:12 PM
lawnmowerhombre's Avatar
Default Interior Bolt color change
I want to change all of the exposed bolts on my inner door cards to black. Anyone know of good vendors that have quality options for this?
Patrick
Old Feb 7, 2025 | 12:32 PM
CincyRovers's Avatar
Patrick
They're just Torx T30 bolts. I'm sure you can easily find black T30 bolts. You're the first person I've seen on this forum (and in general) to ask about this. Best of luck!
Old Feb 7, 2025 | 02:36 PM
SilverSFR's Avatar
They also make colored caps/plugs that fit over the bolts and into the holes. These caps hide them completely. in the color of your choosing.
or google "Machine Screw Large Pan Head T30 M6X10 Black" The 10 in the number is the length in mm. I am unsure of the OEM length but you can easily take one out and give it a quick measure.
Old Feb 7, 2025 | 03:23 PM
tbrown's Avatar
Powerful UK has them: https://www.powerfuluk.com/collectio...-110-130-black
Old Feb 8, 2025 | 03:32 AM
A1C6's Avatar
The OCTA also has different coloured bolts on its doors. They are kind of brown iirc
Old Feb 8, 2025 | 12:39 PM
On the OCTA Edition One, they are a dark chrome finish.
Old Feb 8, 2025 | 06:03 PM
Found these titanium ones that appear to have the look and feel that is on par with the OCTA.
https://rohmy.com.au/collections/new...panel-bolt-kit
Old Feb 9, 2025 | 10:45 AM
AAJR's Avatar
Nice set, but be aware that it does the doors only. So the center console bolts and the rear door bolts do not appear to be included if you buy 1 set.
Old Feb 9, 2025 | 10:48 AM
Yeah. They have kits for everything else but man it gets pricey. Still nothing for the metal outer discs in the center console which is a bummer. I havent tried to remove one of those does anyone know if they are built into the rail?
Old Jun 7, 2025 | 10:19 AM
Found some great titanium bolts that are much cheaper than the Hunters Prestige or Startech options. I did end up powder coating the center console discs. I like how they just sink into the interior now. Door cards are next!
