Johnson Rods 1.5 lift vs Proud Rhino 2
I had the Johnson 1.5 lift and just switched to the proud rhino 2 lift. Someone here said they felt that the 2 lift ride quality was too harsh and bouncy. I cant tell a difference at all. Subjectively I think the 2 looks a bit better.
2 Proud Rhino
1.5 Johnson Rod Lift
2 Proud Rhino
Too funny. I just swapped the 2 PRs for 1 1/2 JRs last week. That was my post complaining about front end bounce, not necessarily in normal mode but definitely in the off road.
Since the swap out ,I havent taken it out of the garage, so I cannot report on the bounce nor the new visual appearance.
SmokinV10 (01-09-2021)
Getting ready to install Johnson Rods 1.5" w/ K02's on my x... I think either, with larger all terrains looks SO MUCH better than stock, and to me seems they way a Defender should come from the factory. On a side note, I have a kind of off topic question for you: were your fender arch trim pieces gloss black from the factory or did you wrap or paint them? Just had mine installed and they are matte gray. The guys at my dealer said they only come matte gray, but I have seen several images where they are matched to black gloss trim. Looks much better matched.
