Knocking under body
Old Jan 17, 2024 | 12:55 AM
Macca61's Avatar
3rd Gear
Default Knocking under body
Hi
I have a 2021 D250 110 and recently started getting a knocking under the body at idle and suspect it’s the exhaust touching somewhere it’s booked in but all they can give me is end of March has anybody else had this issue ?
Old Jan 17, 2024 | 02:02 AM
lightning's Avatar
I've not heard any other owners complaining of this.
Is there any way you can get underneath it and have a look? Do you have a friendly local mechanic who has an inspection ramp maybe.
Old Jan 17, 2024 | 06:43 AM
GCSchmidt's Avatar
I have a 2022 110 P300, and had that noise as well. I tracked it down to the cat heatshield on the exhaust. It was my fault...I dented it off-roading, I fixed it by gently hammering back. Hammers fix a lot of things, hahaha
Old Jan 17, 2024 | 08:05 AM
lightning's Avatar
Just a note
Never hit a catalytic converter with a hammer, you'll shatter the internal matrix.
Old Jan 17, 2024 | 08:07 AM
GCSchmidt's Avatar
Just a note
Correct, I gently tapped the dent to the outer heat shield, the seam was touching the cat.
Old Jan 17, 2024 | 11:22 AM
Dogpilot's Avatar
I get that noise as well, but usually only after running down big groups of Zombies. Occasionally one gets stuck down below and makes that noise. They are actually very difficult to dislodge, as they are quite gooey. Garden rake seems to work the best.
Athana
May 9, 2018 07:47 PM
ClayinSA
Nov 29, 2017 10:15 AM
Brian Mills
Jul 25, 2017 11:00 AM
mikec205
Jun 9, 2017 06:26 AM
gypsy
Jan 11, 2017 04:26 AM
