Lift Rods vs. IIDTool for Custom Ride Height: Pros and Cons?
Old May 20, 2024 | 09:52 AM
jpschwinghamer's Avatar
Default Lift Rods vs. IIDTool for Custom Ride Height: Pros and Cons?
Howdy everyone,
I've been pondering the differences between installing lift rods and using the IIDTool to set a custom ride height. To my understanding, both methods achieve the same goal: one through hardware, the other through software.
The IIDTool seems like the more versatile option, allowing adjustments as needed. However, I'm curious if there are any potential downsides to using the IIDTool that I might be overlooking.
Any insights or experiences you can share would be greatly appreciated!
Thanks, JPS
Old May 20, 2024 | 10:20 AM
NoGaBiker's Avatar
Originally Posted by jpschwinghamer
Howdy everyone,
Thanks, JPS
I have no experience with the IIDTool, but considered it when I was first building my Defender. I opted to order the 1.5" rods and throw them in my recovery bag in back. Other than testing them for fit and to familiarize myself with how to install so I could do it in the field, I've never put them in. Definitely wouldn't ride around with them all the time. But then, I run wheel/tire combos that fit and would only use the rods or the IID Tool for actual rock-crawling where getting the body a little higher has benefit. But so far, I've not felt the need for them so they sit in the back.
In your shoes I'd order a cheap set of rods and see if you need them and how much trouble they are to install (very little) and then weigh that experience against the cost of the programmer.
Old May 20, 2024 | 10:59 AM
GavinC's Avatar
Howdy everyone,
Thanks, JPS
If you are buying a GAP tool. And there are many great reasons do do so. Lift rods are obsolete.
GAP provides a lift/lower for minutes or months on demand. Activate it on the fly. It does what a LLAMS kit does without the expense and install.
A rod gives you 1 predetermined lift. GAP gives you a variety of customizable ones that you can change whenever you feel like it.
Ride around stock all day, hit the trails and add a 1" lift, encounter an obstacle, activate super extended height, then back down to regain travel. On the way home, revert to stock. "Oh no. My rack is loaded with skis and I cant fit in my garage". No problem. Drop down to ride the bumpstops and sneak on in.
It's win win.
Add all the other benefits GAP gives you and it's a no brainer.
If you camp you can also use it to level each corner of vehicle. Handy for RTT users.
Old May 20, 2024 | 11:29 AM
tbrown's Avatar
Is this lower than the access height? If so, I'm going to have to investigate!
Old May 20, 2024 | 11:30 AM
It's win win.
Awesome! I'm sold.
JPS
Old May 20, 2024 | 11:36 AM
GavinC's Avatar
yes about 40-45 mm below access. Very handy
Old May 20, 2024 | 03:17 PM
tbrown's Avatar
sweet!
Old Jul 13, 2025 | 07:05 PM
DefenderSISU's Avatar
Default New rods are coming
Guys Saltek Motorsports is coming out with a set of lift rods that are adjustable from factory ride height to +2 inches. I’ll be ordering a full set when they come out.
Old Jul 18, 2025 | 01:24 PM
lawnmowerhombre's Avatar
I plan to go to 35s and plan to do some bumper cutting and cooler relocation. I would love to NOT have to run lift rods. With GAP tool height changes does this help with the harshness at full height you end up with when you use lift rods?
Old Jul 18, 2025 | 10:25 PM
GavinC's Avatar
it will behave identically to lift rods.
rods change hardware leaving software unchanged.
Gap changes the software while leaving the hardware unchanged.
identical outcome. Identical pros and cons.
identical.
