LR telling me that I can't downsize to 20's?
Old Feb 25, 2022 | 06:25 PM
sj24k's Avatar
Default LR telling me that I can't downsize to 20's?
ok, so this is odd. and i feel bad for posting this again as i know it's been covered. but i have a 2022 x dynamic HSE 110 p400 coming in shortly. i am getting someone else's cancelled order. it has everything i want except it is coming in with 22" rims - specifically, style 5098 gloss black. i was planning on switching out the 22's to 20's and have been told by many (including folks here, aftermarket wheel shop, and one other LR dealer) that this is no problem to do. but the dealer i am buying the car from had their parts department check with LR NA and they told him that the calipers and the rotors are different sizes and different part numbers on the versions that come with 22's? this is counter to everything i've heard. he did say, when it comes in he'd be happy to find a set of 20's on the lot and "try it out" just to confirm. anyway, am i missing something? should i stress about this, cause i don't think i'm going to want to keep the 22's? anyway, appreciate anyone chiming in with any info here. thanks!
Old Feb 25, 2022 | 07:02 PM
jrod's Avatar
I have put 20" Rotoform Wheels on both of my Defenders that came 22" wheels with no problems.
Old Feb 25, 2022 | 07:28 PM
Bjs1234's Avatar
This does not make much sense unless there has been a recent design change. I would ask for clarification on what has changed in this model since 2021.
Old Feb 25, 2022 | 08:49 PM
Yulongtd6's Avatar
This is impossible. V8s come with 20s and 22s and have the largest brake and rotor combo available.
Old Feb 26, 2022 | 07:09 AM
CombatNinja's Avatar
There may be some running update on a brake caliper part number but I assure you that it is not going to effect fitment.
Old Feb 26, 2022 | 09:21 AM
maxmk8's Avatar
you can run 19s on the p400. It’s only the 18s that don’t fit.
Old Feb 26, 2022 | 02:41 PM
The Insider's Avatar
I work for JLR and can confirm that for standard calipers a 20" wheel works just fine. The caliper specified is the same for 20" and 22" wheels.
Tell them to simply pull up calipers #LR102243 and #LR102246 in their parts system and it should show that a 20" or 22" wheel is acceptable.
Might be they're not interested in the hassle of a wheel swap.
Old Feb 27, 2022 | 12:34 PM
sj24k's Avatar
thanks to all for the feedback. and for easing my mind :-)
_Allegedly
Aug 17, 2021 05:56 PM
aussie_rover
Jul 28, 2020 09:17 PM
Chrisinhouston
May 11, 2009 08:50 PM
luxury1
Dec 20, 2008 06:24 PM
cuda
Jan 5, 2008 04:55 PM
