Motorcycle Hitch Carrier
I might be able to, but I don't think I would. Jenn helps just to keep another set of eyes and hands on it. The rear tire especially doesn't leave a lot of room side-to-side on the ramp/track and I need to lean it slightly towards me to get the handlebar past the spare
But I would bet I could do it easily with a dual-sport or something a little lighter than 400# wet
I am so thankful you posted this. I'm copying your setup and purchasing today. WIll be transporting an array of different bikes but not towing here in California is a big deal because I can get into the carpool lane and avoid traffic. I can also go the speed limit (trailers limited to 55mph).
THANK YOU.
THANK YOU.
Kev M (09-22-2021)
Bumping to vouch for this product as well. It seems to haul my new Husky TX300 (225 lbs) just fine too. I'll report back once I hit some nastier trails to shake it loose (hopefully not) offroad. I'll also need to test it with the Aprilia (460 lbs). The slimmer tire width isn't an issue at all. Personally I will be picking up some auxiliary brake lights & turn signals since things get a bit obscured.
The following 2 users liked this post by ballandchain:
alanconnelly (05-17-2023),
LordExplorer (05-16-2023)
I loaded mine myself, just tilted at a slight angle when loading. Even strapped down, I'm clearing the spare wheel with the bike. Just for safety, I folded and secured the right peg to keep it up and away from the spare wheel.
Kev M (11-12-2023)
Well, guess it's time to bump my own thread then.
I jumped in with both feet and picked up the BlackWidow SMC-600r for the capacity and dimensions it offered.
https://www.blackwidowpro.com/motorc...rs/p/smc-600r/
I've had it a couple of weeks but finally assembled it yesterday and we gave it a test installation and run around the neighborhood before an upcoming trip where we'll be using it in a few weeks.
I have to say the D110 didn't seem to know or care it was there. To use it properly I'm going to have to remove the right side rider's peg to keep it from contacting the spare and I'm going to triple-check the tie-downs, but otherwise it looks like we should be good to go.
Besides using it for this trip it will be nice to know it's available should any of our svelte Italian girls require a rescue (or the same for any of our friends).
Will report back again after the trip.
But this is what I wrote:
Originally Posted by droc234
Hey man how did this work out for you? I’m looking to put a carrier on my 110 for a dual sport
dirt bike.. any issues?
* It's a heavy piece of kit. I'm glad we only use it occasionally because morning/removing the carrier is easier with a second set of hands.
* I'm glad we have it as potential emergency pickup usage for any bike currently in the fleet (all smaller Italian bikes these days).
* But all our bikes are bigger/heavier than most any dirt bike so for us, loading is best done with a helper as well. I bet I'd feel pretty comfortable loading most dirt bikes solo.
* I leave the spare tire in place to protect the hatch, but it means I have to lean a ~400# bike out around the tire during loading/unloading. Again, I bet a dirt bike is easier but keep the tire in mind depending on the width of the bars.
* I added additional lights to the carrier for brake and turn signal. Though they work ok (except in bright sunlight), I probably should have gone with something bigger that thin a LED strip.
That's all that comes to mind.
Ride safe!
Kev
Your inbox is full so I couldn't reply to your pm.
It works just fine for us. Keep the following in mind:
Ride safe!
Kev
Ride safe!
Kev
did you have to use an extention on the hitch to fit the bike? You mentioned you had to remove the peg. Does it hit?
which tow carrier did you get? The black widow 600?
