No Lift tire size guide (work in progress)
#301
275/65/R18 on a Defender 90 P300 Coil Springs
Hi all,
I have fitted Nitto Ridge Grapplers 275/65/R18 on the stock steel wheelies of a 2023 Defender 90S on coil springs.
It took some millimeters away from the space on the suspension arm, see before and afters. I have driven 50 miles so far without any rubbing or issues.
Will I have issues off road?
Stock tires 255/70/R18:
Front left tire
Front left tire
Front left tire
Front right
Front right
Front right
Nitto Ridge Grapplers 275/65/R18:
Front Right
Front Right
Front Right
Front Left
Front Left
Front Left
Front left tire
Front left tire
Front left tire
Front right
Front right
Front right
Front Right
Front Right
Front Right
Front Left
Front Left
Front Left
The following 5 users liked this post by l_adrianza:
Bob.Loblaw (04-14-2022),
GavinC (04-11-2022),
GrouseK9 (04-12-2022),
MattF (04-12-2022),
WAFOX (08-06-2023)
#302
The aluminum “hockey puck” pieces (actually like curved half pucks) are simple bolt-on, bolt off jobs.
They are installed on P300s that run 20” wheels because the P300s run smaller brakes than the P400s, so when running the larger wheels, there is a larger empty space inside of the rim opposite the caliper.
The thinking was that mud could potentially fill and pack into this area during off-roading, possibly resulting in the wheel becoming unbalanced… so they bolted on the puck to fill in some of the space.
The puck is not needed on P300s that run 18” wheels, as the empty space opposite the caliper is small enough that LR engineers didn’t feel there was a threat of unbalancing due to packed mud… so those trucks do not come fitted with them.
I removed my P300’s factory 20” wheels (Style 5098) and put on the factory 18” alloys (Style 5094)… the only modification necessary was the removal of the pucks.
Before:
And after:
This was before I removed the mud flaps
Before:
And after:
#303
Hi all,
l_adrianza (04-12-2022)
#304
For visuals, my 2014 Jeep on 37" bias plies with 8-ish pounds of air:
The following 4 users liked this post by NoGaBiker:
#305
That raises an interesting question that I don't know the answer to: Yes, the low-pressure tire will flex more, but wouldn't that only be on the ground, under force exerted by rocks and other irregularities? I.e., under normal circumstances, a low pressure tire looks exactly the same everywhere except on the ground, where it spreads and flattens out. So my guess is that the parts of the tire carcass near the control arms and other suspension pieces won't change shape even going over rocks at low pressure, where the tire carcass flexes and spreads down near the ground. But I can't say that definitively. Just surmising.
#306
#307
I think i was visualizing more obstacles on steep approach/departure angles, but I also don’t know the answer. On flatish ground I think you are absolutely right.
i’m very interested in anyone running taller 265/70/18 on stock offsets. It seems like some here have had good results
I was scared to try going down to 265/70-18s and getting stuck with 5 more tires I couldn’t use so I ordered stock sizes.
#308
@NoGaBiker Just thought I'd check-in with your experience... I've a P400 and close to pulling the trigger on some OEM steelies and have found a local powder-coating place that can get me blacked out.
Wanting some BFG KO2 255/70R18's and not wanting to use spacers. You think its possible? I'm not afraid to grind down the rear brake caliper studs as much as needed...
#309
Okay, so here’s where I am after about 3 weeks of having everything fettled, including two mild off-roading trips (mild because that’s all we have that’s open around here right now.)
Progression:
1) Bought Lucky 8 rear calipers. Had them installed at my local Land Rover specialists. Looked great.
2) Bought 5 OEM 18” steelies in black, overstock from the Trek Edition trucks.
3) Ordered five 275/70R18 Kenda Klever RT601s. They shipped to Tires Plus shop, who mounted them. I took them home and installed. They rubbed. Not just at access height. They rubbed at all heights. They rubbed with and without spacers. They rubbed with and without 1.5” Johnson rod lift.
4) Sat around mildly cussing.
5) Did nothing but read some more for a few weeks.
6) Decided to go with stock sizes since as I educated myself more plus attended a full-day LR school at Biltmore I began to learn that the larger tires with lower pressure weren’t really what the Defender’s logic was designed for.
7) Since I’d always wanted to try Ridge Grapplers I called my Discount Tire store to order some. They didn’t have any, said they’re on backorder with no delivery date. They have 265/70s though. I was afraid of rubbing with that size and it wasn’t worth it to tempt fate. Tried the internet and no search turned up any available RGs in stock size; some sites said they had them but then would inform me the day after I ordered that they’re back ordered with no date. Shoot.
8) More reading and research. Decided on the Cooper Discoverer Rugged Trek (RT). Good reviews, looks good. Ordered 5 of them.
9) Loaded the “too big” Kendas (still mounted) and the new Coopers onto my trailer and hauled all 10 tires and 5 wheels to Discount Tire. They pulled the Kenda’s and mounted the Coopers to the OEM wheels. Installed on the truck. I had put the 30mm spacers on in case they were necessary. Tires rubbed at anything close to lock. A little noisy but doable. I hooked up the trailer and carried everything back home.
10) Pulled the front spacers, left rears installed. Front Tires quit rubbing but now with no spacers the wheels rubbed on the calipers only under hard braking or cornering. They are close enough that the deflection from those forces will put them in contact. It wore a small groove at the points of contact which made my job easy. I took a 16th to an 8th off anywhere there was contact, making the groove disappear, plus a little more. I also looked at the inside of the wheel barrel to see where it had touched the caliper and took a little off there; it was all at the place where the barrel is welded to the face of the wheel — the contact was basically on the weld bead, and it was only in one place, indicating the weld bead is actually thicker at that place, so taking it down a 32nd or so gets it the same as the rest of the weld.
11) all is well. So the front now works (without spacers) and the rear does as well (with spacers.) No rubbing at any height. I haven’t installed the rod lifts but that should only make things better. I only want to use them on western off-roading excursions so I’ll carry them out there and install at the trailhead to get a little more rocker-panel and underbelly clearance among the rocks.
12) I want to lose the 30mm spacers in the rear, but that will require a bit of grinding. I already did some and the wheels clear, but not the weights. That’s too close for my comfort so I’m going to work on that as soon as I get some new grindstones for my die grinder. No rush though — things look pretty boss with the rears flared.
Original fitment of 255/70R18 Cooper Discoverer RT, with 30mm spacers front and rear:
Same tire with 30mm spacer in rear, no spacer in front. These photos are at OffRoad height because I was just pressure washing mud and gunk out of the wheel wells when I decided to take the pix.
[TL: DR] Executive summary: Current setup is Cooper Discoverer Rugged Trek (RT) in 255/70R18 on OEM 18” steelies, with 30mm spacers on rear and no spacers on front. Small amounts of grinding (or even filing — I used a good steel file for some of it) on the fronts necessary for full clearance under hard braking and cornering.
The following 3 users liked this post by NoGaBiker:
#310
Hi Everyone; first post here with 2022 Defender P300 in Toronto Canada, first LR!
stock rims were 20"; found a set of OEM 19" off 2020 defender; and also found continental wintercontact 850P 255/65/19 locally; has anyone gone through a winter with this setup? if so any advise? thanks in advance!
