No Lift tire size guide (work in progress)
Old 10-06-2022, 11:19 PM
GavinC's Avatar
Received 2,505 Likes on 1,016 Posts
Originally Posted by POPTOPP
What do you mean "no decent offerings in Europe for a modern AT in 265/70 R18"? Vredestein makes a great 3-peak AT in that size and they're a Dutch manufacture. Are the Pinza ATs only sold in North America?
Neither of the AT Vredestein I'm seeing at Tire Rack have the sufficient load rating for Defender. Neither meet the required XL load rating. Maybe there is another type I'm not aware of.
  #402
Old 10-07-2022, 12:18 PM
POPTOPP's Avatar
Once you hit the 32-33 inch or larger diameters, XL load ratings are very, very rare. The ply construction of the Pinza ATs are the same as the OEM Perelli AT XL tires and the load index of 116 / 2756lbs of the Pinzas actually out performs the Scorpions which is only rated at 2601 lbs.
  #403
Old 10-08-2022, 03:19 AM
GavinC's Avatar
Tire load ratings are always a confusing nut to crack. I guess I lack an adequate understanding of them.
I don't find XL rating to be rare in the sizes that fit Defender. At least not in US market. Perhaps it's very different in other jurisdictions.
  #404
Old 10-12-2022, 11:15 PM
EDWARDA's Avatar
6th Gear
Falken Wildpeak AT3 275x55r20. No rubbing at any height
  #405
Old 10-13-2022, 09:20 AM
Jrunr619's Avatar
As we approach winter here, do any of you know how good or bad the Nitto Ridgegrapplers are in the snow?
  #406
Old 10-13-2022, 10:00 AM
TrioLRowner's Avatar
Jrunr619:
I am camped out for a job in the NE US these days, awaiting the first snow.
I will report back on the Nitto RidgeGrapplers in the snow at that time.
Enjoy !
  #407
Old 10-13-2022, 06:18 PM
drshdw's Avatar
I would say from the pics here, https://www.discounttire.com/buy-tir...ridge-grappler, not great, no siping really, say compared to https://www.discounttire.com/buy-tir...wildpeak-a-t3w
Also, not that 3pmsf is end all be all, but w/o it, I wouldn't take them in the snow.
D-Fens (10-15-2022)
  #408
Old 10-18-2022, 09:58 AM
warkeld's Avatar
BFG KO2 265/60/R20 on Stock Rims. Fit is tight in Access Mode Only, and even in Access Mode there is zero rubbing even at full turn lock. One side note, I used Tire Rack Mobile install service, they were unable to balance these tires on the Mobile Truck. I called Tire Rack and they sent me to a brick and mortar tire shop and with the balancer mounter to solid ground and they were able to balance tires no issue. (pics with Defender in Access Mode)
The following 7 users liked this post by warkeld:
bobbo28 (10-18-2022), GavinC (10-18-2022), MattF (10-18-2022), mopadzi (10-19-2022), NoGaBiker (10-18-2022), preetsarai (11-04-2022), The Fulcrum (10-19-2022) and 2 others liked this post. (Show less...)
  #409
Old 10-18-2022, 03:00 PM
bobbo28's Avatar
Can you please confirm that you have the full size mud flaps? Looks like you have them up front, would assume you also have them in the rear.
I have the same truck and have been leaning towards 275/60/20 KO2's w/ a 1" lift, but I really don't want to deal with rubbing or modifying/removing my full size flaps.
Appreciate your feedback!
  #410
Old 10-18-2022, 03:09 PM
bobbo28's Avatar
I think the 265/60/20 is the prefect compromise... it looks great. However with the full size mud flaps, I'm guessing it will likely require some modification/grinding.
warkeld (10-19-2022)
Quick Reply: No Lift tire size guide (work in progress)
