No Power Steering
my power steering went out for about 10 seconds, along with all the electrical in the driver side door. power steering came back but door power did not.
dealer traced it to a loose wiring harness which fixed the electrical, except for the door lock actuator which gets fixed next week.
not sure if the short loss of power steering was tied to the harness or not.
Very common...issues like this are part of the adventure of owning a Land Rover.
https://landroverforums.com/forum/20...ems-ok-109640/
Put put a 10MM wrench in your glove box in case you need to disconnect the negative battery terminal and do a "hard reset" to get the power steering back. Like this insulated one:
https://www.jbtools.com/knipex-98001...sulated-10-mm/
The following 3 users liked this post by PaulLR:
![Smile](https://landroverforums.com/forum/images/icons/icon7.gif)
THANK YOU! Disconnecting the negative battery terminal FIXED my power steering!!! You saved the day!
Thanks again![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Thanks again
If/when the car comes back from the dealer I will see if this works
https://www.harborfreight.com/10mm-s...nch-97260.html
Someone posted a pic over on Defender2 showing the OS update 4.1.5
In the release notes it says this issue has been addressed.
https://www.defender2.net/forum/post...0.html#1031390
