Onboard air Mod , Viair 485c + 2 gallon tank - ext.output
Old Sep 1, 2021 | 03:56 PM
Defendit..'s Avatar
Default Onboard air Mod , Viair 485c + 2 gallon tank - ext.output
So next mod, Air.
Not very impressed with the Landrover aircompressor.
My demands: Quick refill after deflating (I use the Staun deflators )
Aircompressor Viair 485C constant duty 200psi
Airtank 2 gallon
Pressure switch relay 165 psi / 200 psi
Regulator max 220 psi
Straight from battery with 40 amp fuse
Viair pressure gauge
Carling HR rocker switch DTDP
​​​​​​Prevost S1 euro safety coupler 1/4" female tread ( max. 175 psi)
Elbow 1/4" male/ female
Flexzilla 3/8" hose 300psi
First setup
Did have the Flexzilla professionel crimped.
Regulator set to 160 psi
Viair gauge backlit on the Interior lighting.
Carling switch
Prevost S1 safety coupler external
Everthing is working fine, relative quiet, nice to have a full tank of air before leaving offroad, refill of the first Tire from 20 psi to 34 in 30 seconds.
All four in just over 5 minutes.
Old Sep 1, 2021 | 09:17 PM
NoGaBiker's Avatar
Dang son, that’s some impressive work. Hat’s off.
Old Sep 2, 2021 | 04:07 AM
Defendit..'s Avatar
Thx. NoGaBiker.
I'll try to modify my 90 to be ready for some serious offroad.
I'am not mounting the Hi-Lift on my rear door. Instead I'am thinking of an Airjack..
Let's proceed with the mods !
Old Sep 2, 2021 | 06:25 AM
DefXBill's Avatar
Very nice work! 110 or 90?
Old Sep 2, 2021 | 11:30 AM
DoctorofRocks's Avatar
Very nice - would love to see a schematic or build outline if that's not too much trouble to put together.
Old Sep 2, 2021 | 03:48 PM
ADVAW8S's Avatar
Too bad, you can't go F1 style and install jacks into the bottom of the defender. Have 4 switches of just one that raises the whole car up.
Old Sep 2, 2021 | 10:54 PM
Defendit..'s Avatar
Looking for this kind of Air Jack
https://www.vevor.com/products/air-j...-hose-extensio
redwhitekat
Jul 17, 2021 12:25 AM
tobitobsten
Range Rover Classic (1st Gen)
Jan 9, 2020 02:33 PM
tobitobsten
Jan 6, 2020 08:06 AM
abran
Oct 19, 2018 08:26 AM
CandiMan
Aug 18, 2008 08:51 AM
