P300 Cooling Fan
P300 Cooling Fan
Anyone else with a P300 experience the cooling fan run at full speed after shutting the car off? MY22 P300 will ramp the cooling fan up to max power any time you park and let it idle for more than maybe 10 seconds. This happens any time its over maybe 65 degrees ambient, which is most of the time in Phoenix. Slightly irritating, and people occasionally ask if I've left the car running accidentally. This will be the car's first summer, and I can only imagine how long it'll be roaring away in the parking lot.
TrioLRowner (04-06-2022)
I have a 2022 P300 and also live in Phoenix - I notice the fan running after turn-off about 20% of the time. I picked my Defender up back in Sept 2021 and we had some pretty hot days - no real issue with the fan. If yours does seem to run a lot, I would have the dealer take a look at it.
Related to a degree - my Audi RS6 (V8 twin turbo) will run the fans (actually its running the cooling system) every time I turn it off. No matter the weather etc. This is done to keep the coolant running through the turbos to manage heat... wonder if it might be similar for the Defender.
Matt
Matt
TrioLRowner (04-07-2022)
Matt
Matt
P300 Turbo is water - cooled and the oil needs cooling, also.
And it seems to somehow be able to independently spin as it cools, or so it sounds to me when it is hot and the engine is off. I recall there appears to exist a small pressure tank which bleeds to turn the impeller.
Land Rover Defender 110 Engine Parts
2. 0 liter. Lower. Outer. Top. Upper.
Add All to Cart
[size=13px]This Fits Your 2020 Land Rover Defender 110 S Sport Utility 2.0L Ingenium A/T[/size]
View Full SizeTURBOCHARGER & COMPONENTS.
Add All to Cart
Product Name
Price
Part Number
Qty.
EXHAUST MANIFOLD. Turbocharger.
2.0 LITER. A complete turbocharger assembly. Exhaust Manifold. Incl.Integrated Exhaust Manifold. Incl.Turbocharger. Includes Exhaust Manifold On The 2.0L Gas And 3.0L Engine. Includes Exhaust Manifold On The 2.0L Gas Engine.
(Current price)$ 2,129.76
LR116338
Add To My Cart
Gasket. Manifold. Exhaust.
2.0 LITER. Turbocharger gasket. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Manifold Gasket. Turbocharger Gasket.. Turbocharger.
(Current price)$ 29.35
LR091554
Add To My Cart
Gasket. Converter. Turbocharger. Seal.
2.0 LITER. Turbocharger seal. 2.0 LITER. 2.0 LITER GAS. 2.0 LITER GAS 2021. 2.0 LITER PHEV. 2018-21. A component which prevents a leak or provides a sealing surface at the Catalytic Converter. CONVERTER & FRONT PIPE. Gasket for Catalytic Converter System. Outer. Outlet. Turbocharger Gasket. Turbocharger Oil Seal. AND pipe. Oil. TURBOCH. Catalytic. FLANGE. MANIFOLD.
(Current price)$ 22.13
LR105411
Add To My Cart
Clamp. Converter. Pipe. Exhaust.
2.0 LITER. 2.0 LITER Gas 2018-20. 2.0 LITER Gas 2021. 2.0 LITER PHEV. Catalytic Converter Clamp. Clamp for Exhaust.. and. Catalytic. Turbocharger.
(Current price)$ 63.02
LR105414
Add To My Cart
Shield. Heat. (Upper)
2.0 LITER. Heat shield. PartQualifier: upper. upper. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Turbocharger Mount.
(Current price)$ 31.97
LR091546
Add To My Cart
Shield. Heat. (Lower)
2.0 LITER. Heat shield. lower. PartQualifier: lower. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Turbocharger Mount.
(Current price)$ 24.37
LR091551
Add To My Cart
2.0 LITER. Heat shield. PartQualifier: top. top. Upper. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Inner. Turbocharger Mount.
(Current price)$ 26.15
LR091550
Add To My Cart
Shield. Heat.
2.0 LITER. Heat shield. outer. PartQualifier: outer. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Exhaust Heat Shield. Turbocharger Mount Heat Shield. TU. Exhaust. Side. Turbocharger Mount.
(Current price)$ 22.77
LR091549
Add To My Cart
Turbocharger Coolant Line
2.0 LITER. Water inlet.
(Current price)$ 55.66
LR092089
Add To My Cart
2.0 LITER. Water outlet.
(Current price)$ 54.95
LR134606
Add To My Cart
Hose. Coolant. Line. (Upper)
2.0 LITER. By-pass pipe. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. Engine Coolant Hose. Line used to transmit oil amongst the turbo, interCooler and Engine. Turbocharger Coolant Line. By - Passenger pipe. Engine. Turbocharger Oil.
(Current price)$ 57.06
LR108956
Add To My Cart
SEPARATOR. Water. Coolant. Valve.
2.0 LITER. 2.0 LITER GAS. 2.0 LITER PHEV. 2018-19. 2018-21. A manifold vacuum actuated valve designed to release pressure in the intake system of a turbocharged engine when the throttle is lifted or closed. Radiator Coolant Hose Adapter. COOLING. Radiator Hose Adapter. Turbocharger Intercooler Diverter.
(Current price)$ 82.46
LR093489
Add To My Cart
13
Turbocharger Oil Line
2.0 LITER. Oil feed tube.
(Current price)$ 56.21
LR091576
Add To My Cart
14
Turbocharger Oil Line Gasket
2.0 LITER.
(Current price)$ 4.85
LR073671
Add To My Cart
15
2.0 LITER. Oil return tube.
(Current price)$ 34.61
LR100575
Add To My Cart
16
Ring. Oil. Tube. (Upper)
2.0 LITER. Oil return tube o-ring. PartQualifier: upper. upper. 2.0 LITER. 2.0 LITER Gas. 2.0 LITER PHEV. 2018-21. 3.0 LITER I6 Gas. 3.0 LITER I6 MHEV. Return. Turbocharger Oil Line Gasket. Turbocharger Oil Line O-Ring. Upper. Sealing. Drain o -. Outlet o -. Return Seal. Turbocharger Line Gasket. Included with: Oil Return Tube.
(Current price)$ 4.96
LR136779
Add To My Cart
17
Ring. Oil. Tube. (Lower)
2.0 LITER. lower. Oil return tube o-ring. PartQualifier: lower. 2.0 LITER. 2.0 LITER Diesel. 2.0 LITER Gas. 2.0 LITER PHEV. 2018-19. 2018-21. 3.0 LITER I6 Gas. 3.0 LITER I6 MHEV. Lower. Return. Turbocharger Oil Line Gasket. Turbocharger Oil Line O-Ring. Drain o -. Outlet o -. Return seal. Turbocharger Line Gasket. Included with: Oil Return Tube.
(Current price)
