Panoramic Roof - Yes or No
#22
#23
The following 3 users liked this post by mopadzi:
#24
Hello, everyone, I'll just add. If you are thinking of driving the car in the field, then without the skylight roof. You will avoid problems with the functionality of the window, in the future with leaking into the car and especially problems with the windscreen and its crackling.
The following 4 users liked this post by DefenderSISU:
curb-optional (05-20-2023),
ficklma1 (11-21-2022),
MattF (11-21-2022),
The Phantom Menace (06-20-2024)
#26
I have pano roof on a 90, I would say it is a must for me.
I love it and open it tilted all the time in the summer.
I almost never slide it back.
Sunscreen is almost never closed when driving.
Not had a cracked windshield since I got it, knock, knock, in April, 10K driven so far, several offroad trips, lots of gravel and forest roads.
jusmax88 (11-20-2022)
#27
mrego - Yes, it does. A car with a sunroof has a reduced torsional strength of the bodywork, which also causes the windscreens to crack due to the tension in the bodywork when crossing large bumps, i.e. when driving in the field. Unfortunately, that is the case. If you have the option, take a car with a sunroof and without a sunroof to the dealer on the off-road track and you will immediately know the difference in torsional stiffness of the bodywork when the car's wheels are cut out. The sunroof bodywork also makes more creaky noises and this will get worse with time. Personally, I don't have a sunroof and I have specifically requested this from the manufacturer. I use the car in the field. I have a roff rack a loaded accessory and therefore the window is meaningless. Another aspect is the use of the car on dirt roads if the window was still closed anyway. I have written about leaks and mechanical failures due to humidity and dust. Who uses a car but only on the road and without a sunroof, the sunroof is a pleasant addition.
#28
Based on the stuff in this thread https://landroverforums.com/forum/20...0-news-112838/ I feel like i got a unicorn here. Super excited and clearly pics will be provided. Thanks for all the good help and advice
EasternShoreDefender (11-21-2022)
#29
Thanks, mopadzi. Great insight. It makes sense that a difference in torsional strength would be present between the SR and no-SR models. The creaky noises is what I've read in early production vehicles. Maybe LR fixed the issue with the newer ones.
Congrats, eyejayehh. Enjoy the ride home. I am sure you will love it. This is a great road tripping car.
#30
I too load my lr2 roof - rails with cross bars. The noise at highway speed is terrible through the glass. The ratchet straps vibrate in the wind, and the ends can slap the glass. No damage, but it’s a loud racket. You don’t have noise from your panoramic roof??
