Panoramic Roof - Yes or No
Old Nov 17, 2022 | 09:27 AM
  #21
EyeJayEhh's Avatar
Very good thoughts and my first car was a 1972 VW Squareback!!! Max was his name and I can still smell the interior!!!!
Old Nov 17, 2022 | 10:08 AM
  #22
Trekkie's Avatar
Originally Posted by NoGaBiker
Do you mean "new" cars? Otherwise, I'm not sure I'm following your logic.
LOL, boy I typed that wrong. Yes, New. I've bought one used car in 30 years of buying cars It was for my kids to learn to drive in.
Old Nov 18, 2022 | 01:20 AM
  #23
mopadzi's Avatar
Hello, everyone, I'll just add. If you are thinking of driving the car in the field, then without the skylight roof. You will avoid problems with the functionality of the window, in the future with leaking into the car and especially problems with the windscreen and its crackling.
Old Nov 18, 2022 | 09:51 AM
  #24
mrego's Avatar
Oh well... I did not know the windscreen "self" cracking issue had to do with the sunroof. Certainly another good reason to avoid it for sure. At least with early MYs 2020, which was the first batch of cars. Maybe LR corrected the issue later on.
Old Nov 19, 2022 | 10:02 AM
  #25
DefenderSISU's Avatar
I have the sunroof with black interior and oyster, headliner and since I use the roof rack a lot to me it’s not a must have because when I have everything on the roof rack you can’t see out of it anyway.
Old Nov 20, 2022 | 07:32 PM
  #26
Brock Samson's Avatar
I have pano roof on a 90, I would say it is a must for me.
I love it and open it tilted all the time in the summer.
I almost never slide it back.
Sunscreen is almost never closed when driving.
Not had a cracked windshield since I got it, knock, knock, in April, 10K driven so far, several offroad trips, lots of gravel and forest roads.
Old Nov 21, 2022 | 03:22 AM
  #27
mopadzi's Avatar
mrego - Yes, it does. A car with a sunroof has a reduced torsional strength of the bodywork, which also causes the windscreens to crack due to the tension in the bodywork when crossing large bumps, i.e. when driving in the field. Unfortunately, that is the case. If you have the option, take a car with a sunroof and without a sunroof to the dealer on the off-road track and you will immediately know the difference in torsional stiffness of the bodywork when the car's wheels are cut out. The sunroof bodywork also makes more creaky noises and this will get worse with time. Personally, I don't have a sunroof and I have specifically requested this from the manufacturer. I use the car in the field. I have a roff rack a loaded accessory and therefore the window is meaningless. Another aspect is the use of the car on dirt roads if the window was still closed anyway. I have written about leaks and mechanical failures due to humidity and dust. Who uses a car but only on the road and without a sunroof, the sunroof is a pleasant addition.
Old Nov 21, 2022 | 07:28 AM
  #28
EyeJayEhh's Avatar
This is all fantastic advice.....and based on how we will be utilizing the vehicle (as in not driving up Mt. Kilimanjaro....although that would be pretty sweet ) it will be light to moderate off-road activities that will merge into some RTT camping. As it turns out, I was able to find a MY23, Tamsin Blue, white roof, pano roof, 18" steelies, air suspension, off road pack (exactly what i wanted basically) one state over and its coming home with me on Wed!!!!
Based on the stuff in this thread https://landroverforums.com/forum/20...0-news-112838/ I feel like i got a unicorn here. Super excited and clearly pics will be provided. Thanks for all the good help and advice
Old Nov 21, 2022 | 08:47 AM
  #29
mrego's Avatar
Thanks, mopadzi. Great insight. It makes sense that a difference in torsional strength would be present between the SR and no-SR models. The creaky noises is what I've read in early production vehicles. Maybe LR fixed the issue with the newer ones.
Congrats, eyejayehh. Enjoy the ride home. I am sure you will love it. This is a great road tripping car.
Old May 20, 2023 | 08:05 PM
  #30
curb-optional's Avatar
I too load my lr2 roof - rails with cross bars. The noise at highway speed is terrible through the glass. The ratchet straps vibrate in the wind, and the ends can slap the glass. No damage, but it’s a loud racket. You don’t have noise from your panoramic roof??
