Pirelli Scorpion XTM AT tires
ok so I am going to post this question here, I have the OEM pirellis...and here is my problem, i try to fill my tires with air any my home unit cannot fill it....seems like the air cannot fill the tire fast enough and more air escapes....thoughts?? anyone else have this issue? i have to go to a gas station to fill my tires with air and even that can be a challenge??
1- Your air hose is not properly sealing over the valve stem. Make sure it is firmly pressed over the valve stem.
2- Your valve stem could be damaged; could be loose or broken. Test it with soapy water by spraying it over the valve. If it bubbles, you have a leak there.
I've never been a big fan of Pirellis - years ago they used to make great tires, and they still make decent R-compound summer tires. I find their all-seasons and even their summer tires lack grip. Spinrelli's as I call them.
This new all-terrain seems to be impressive, though!
If I ever decided to go with street tires for my Defenders (maybe 2nd set of wheels), I will prob. go with Pirelli.
I was never fan of Pirelli tires either on sport cars but for my Macan all season OEM tires (PIRELLI SCORPION VERDE ALL SEASON), it was actually quite good (good wear, less noise and good grips).
My Macan came with the Michelin Latitude Tour HPs, which didn't fit the character of the car. Very much a touring tire and not a performance tire. I abused them and needed to replace at 15k miles, and I wanted the Michelin Pilot Sport AS4, which is an OEM tire on the 21" wheels, but unavailable on the 20" wheels, which I have. I put the PSAS4s on our Q7 and love them. I ended up going with the Continental DWS06+ for the Macan, and they're so much better. Quiet, comfortable, loads of grip, and significantly faster on the autocross course.
We may be too off topic but thanks for the info. I will avoid Michelin Latitude when time comes.
