Pivi software update?
Yes thank you. I just got a notification TODAY to update PIVI - im hearing from others that it screwed up their system,
Also, what do you mean when folks said it screwed up their system?
I am new to this system, My old RR (2019) had the previous version and even map updates had to be downloaded.
But...If you go to settings I think you are able to choose what appears in the instr guage cluster.
Unfortunately, I have not been able to find a single related setting. I have toggled between which nav I want on the central screen I.E. Pivi or Apple Carplay and it changes on the main screen but nothing changes on the IDD
I called the 1-1800 customer service number and when they pulled up my car they said there were no available updates that they could push to my car and that they believed it to be up to date. I am not sure if this is accurate from what I have been reading so this is truly frustrating
If you go to the area that is accessed by using the steering wheel menu option, there is a choice between 2 gauges-1 gauge-info-map. That is where you can have the map on your middle instr cluster.
