Proud Rhino 1.0" Lift, OEM Raised Air Intake, Cross Bars, New Tires (Again)
Old Nov 17, 2020 | 01:12 PM
JesseRohr's Avatar
Default Proud Rhino 1.0" Lift, OEM Raised Air Intake, Cross Bars, New Tires (Again)
So I had an issue with three of the five BFG tires that I purchased previously. Simply put, they were out of spec so much so that you could feel the misshapen tires at low speeds as well as high speed. Swapped to the same size 275/55/20 Nitto Ridge Grappler (E Load Range part number 217330) that are 32.13" tall.
I also tossed on the OEM Raised Air Intake (snorkel) and the OEM cross bars along with the Proud Rhino 1.0" lift from Lucky8.
Here's the results:
Offroad Height:
Normal Height:
Old Nov 17, 2020 | 02:49 PM
Moretti's Avatar
Did the snorkel make any noticeable difference in terms of audible noise from the engine (in a good way) ?
Old Nov 17, 2020 | 03:19 PM
Looks great!
Old Nov 17, 2020 | 03:27 PM
JesseRohr's Avatar
Ironically it did. Mainly because the pickup is nearest the driver window now.
Old Nov 17, 2020 | 05:50 PM
AldoRay's Avatar
Default Raised intake
Interested to know if you noticed that the raised intake obstructed any of your view of the drivers side A pillar? It looks like it would.
Old Nov 17, 2020 | 07:22 PM
JesseRohr's Avatar
You can’t even see it from the drivers seat.
Old Nov 17, 2020 | 07:28 PM
Apxlvr's Avatar
Saw this on the FB group looks awesome...sadly I won't be doing a lift since I wouldn't be able to fit it in my garage
Old Nov 17, 2020 | 07:48 PM
AldoRay's Avatar
Good to hear! 👍👍👍
Old Nov 20, 2020 | 08:46 AM
JesseRohr's Avatar
Thanks. I live in a 100 year old home in Downtown Birmingham, AL and my garage door is very typical for the states, it fits in access mode with the cross bars installed.
Davis31052
Jul 10, 2020 11:37 AM
britm3
Dec 10, 2019 11:28 AM
britm3
Dec 9, 2019 03:47 PM
Sakm_5
Nov 12, 2019 08:18 PM
techniq808
Mar 22, 2016 01:26 PM
