Proud rhino rear door table
Anyone have this yet / good or bad feedback?
https://lucky8llc.com/collections/de...n-galley-table
Looks new -- and unlike every other table, it doesn't have all the dumb holes in it and I like the latching mechanism. Just about to buy one - will report back when installed.
I like all the dumb holes. I use them to hang dumb stuff; utensils, trash bag etc. My 2 rubles
Also, without a built-in bottle-opener, is it even a table?
Top left. Load bearing bottle opener
You make a good point about the surface area. hmmm.
Re holes - Depends on usage, yes. For my tailgate cocktail parties I’ve needed to fit in a cutting board to prevent things from falling thru. I have an Amazon sourced table on there now that looks sort of like yours.
I shall report back!
I have the P-UK version in a box but haven’t mounted it yet. The only thing I note is that the Defender versions cost about $200 more than a Jeep version that’s largely identical except for mounting particulars.
@nashvegas - I hang crap off the holes, but not as much as @NoGaBiker . I have so much "crap" in the back on my outings/camping that I don't like the extra space stuff that things on the door steals. It's only for small, quick items I need. Maybe I'll hang TP off of it! BTW - Mine was from the Ukrainian "Alex" off of Facebook. Great quality, did the deed. Only problem was I bone-headedly ordered Gray and not black. Nothing that a little rattle can won't cure...
Anyway, I took a leftover piece of cherry and milled it pretty thin. Then I roughed out the bottom to allow space for straps. Six screws (painted black) and back in business. Now when I want to use the table, I don't worry about crap falling thru and it looks pretty/prettier.
Pro-tip: Regardless of which one you buy, make DARN sure that you get one like Lucky8 or the one I wound up with that does NOT cover up the door storage. I think those were early versions/repurposed Jeep versions that block a great place to store crap needed when cooking.
The following 3 users liked this post by GrouseK9:
