Question About Jack Points and Stands
Good afternoon all. I’m scratching my head because I’d like to place my 90 on a jack stand so I can safely remove a tire to work. Problem is if I jack it up (bottle jack) using the front side point, there’s not enough room to fit the jack stand also under that point. Some other cars have a front jacking point—I assume for this purpose—but I think we just have the 4 side points. Can anyone suggest another safe jacking point I could use or some other method to get a jack stand to hold up a corner?
Thanks,
K
Thanks,
K
I looked over the user manual (useless) and the iGUIDE app (even worse) and found nothing (hence this thread) but after searching the net until my eyes popped out I found a link that, I think, is for a version of the 90 showing jack stand points just interior to the axels. Here’s a few pics. Thoughts?
This came from an accessory fitting guide hierarchy from here: https://topix.landrover.jlrext.com/t...4!G2745447!0!5
This is potentially a really useful point of information. Thank you.
I just came out from under my D110 P300 and think I have confirmed the locations for the jack stands. They are not large and will require some blocking to make sure nothing is damaged (as noted in the instructions). The points seem to be hefty enough and are basically where the suspension components are mated to the sub frame.
As I remove the shielding as part of the Rock Slider install, I will take photos and share to see, if you confirm the locations. Should be in about 10 or 15 days from now.
Cheers,
K
Ok here’s a couple of lighted underside shots. The flatter trapezoidal shape is the front and the circular bolted (suspension to sub frame) joint is in the rear.
I’m not as certain about the rear as I am about the front only because the highlighted shape on the diagram is not easy to decipher.
Thanks!
