Question About Jack Points and Stands
Old Jan 5, 2022 | 09:44 AM
  #41
TrioLRowner's Avatar
The two pictures shown (one with a bolt and the grooved flat pad) by A FACELESS MAN are the correct fore and aft lift points.
  #42
GrouseK9's Avatar
That looks to be one fine collection of cassette tapes, @michaellenzi !
Old Jan 5, 2022 | 09:49 AM
  #43
_Allegedly's Avatar
With a bucket full of pencils.
Old Jan 5, 2022 | 09:53 AM
  #44
_Allegedly's Avatar
https://www.autoliftproduction.com/en-us/autolift3000
Interesting lift. I think I saw their promo photo in a safety video one time. Stacked 4x?!
Old Jan 5, 2022 | 09:59 AM
  #45
Muppetry's Avatar
Originally Posted by TrioLRowner
The transverse lifts (used in most shops I think?) place 4 points loads within the monocoque structures fore and aft -- through the approved lift points.
JLR is trying to keep us away from hanging the entire weight of the vehicle from anything other than the four lift points.
I think that you are incorrect. Having looked further in the service manual, past the section quoted above about 4 post lifts and rails, there is the following, which unless I'm completely misunderstanding, shows how to lift the entire vehicle by the standard jacking points (not the inner points), wheels free, using a 2-post lift. That's effectively identical to the method I posted above.
Old Jan 5, 2022 | 10:13 AM
  #46
Yes, those four wheel changing jacking points are also supported for lifting the vehicle within the manual.
Basically, there are eight approved points to place point loads on the vehicle. Vertical lift loads are not "allowed" elsewhere than those eight points.
I was forced to look into the heavier duty points because my rock crawlers cover the four wheel changing jacking points and I wanted to confirm a suitable alternative.
Old Jan 5, 2022 | 10:22 AM
  #47
Muppetry's Avatar
So those are the ones that I'm using with the Quickjack system, so that should be fine. What's still not clear to me at all is the caveat about not using a 4-post lift with longitudinal rails. It's stated as a safety concern, rather than a structural damage concern, but with no elaboration. But I don't know exactly what configuration they are talking about - obviously not a 4-post lift using the sill jacking points.
Old Jan 5, 2022 | 10:35 AM
  #48
michaellenzi's Avatar
Keeping it lo-fi. Just like my mechanic skills.
Old Apr 3, 2024 | 08:04 AM
  #49
Can_Glu's Avatar
Originally Posted by Muppetry
I prefer a single lifting solution rather than messing around with floor jacks and jack stands:
Would you mind to share which model of Quickjack you use? Apart from the max load, they fall in either 60" or 66" between supporting points. Do you have to use the longer one on your Defender? Thanks for your help in advance.
Old Apr 3, 2024 | 09:40 AM
  #50
GavinC's Avatar
Patent Pending
